Thread Number: 16619
KDS-19 question from email I received |
Post# 274940   4/13/2008 at 09:13 (5,850 days old) by varicyclevoice (Davenport, Iowa)   |   | |
Some of you are more technically savvy than I am and wondered if you could help out a person who sent me an email with this question: Regarding a KitchenAid Superba KDS-19-- I’ve re-installed this machine twice and replace the pump once. Now, for some reason, the unit won’t pump dry. It leaves water in the sump, up to about 1/4 inch across the entire pan (casing) surface (doesn’t leak over the door sill). I notice on the right side of the sump, near the power-in of the heater element, is a stub fitting that looks like a sensor. Is this the water level sensor? If it is, how do I test it? I’ve got a digital multi-meter etc, and everyday experience with electrical circuitry and sensors - - - so am not intimidated by a schematic. Do you know where I can get one on the net???? Regards, Dave from PA |
Post# 274972 , Reply# 2   4/13/2008 at 18:42 (5,850 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 274988 , Reply# 4   4/13/2008 at 21:08 (5,850 days old) by jons1077 (Vancouver, Washington, USA)   |   | |
