Thread Number: 16774
Miele dishwasher rack starting to rust, |
Post# 276886   4/26/2008 at 10:39 (5,842 days old) by bellalaundry (St. Catharines, Ontario, Canada)   |   | |
Post# 277051 , Reply# 2   4/27/2008 at 09:55 (5,841 days old) by bajaespuma (Connecticut)   |   | |
There's also a liquid vinyl coating that you can buy at Homo Depot or Lowe's. It's available in spray or liquid(use the liquid). Unfortunately, it only comes in white, black, blue, red and yellow, so if the Miele racks on your model aren't white... It works well, but you have to let it cure for a while. I've also used a wire cutter to surgically remove rust spots on racks and then capped the cut ends off with those little plastic cap ends that you can also buy at hardware stores.
