Thread Number: 16861
KD-15, 16, 17 Motor seal question |
Post# 278109   5/3/2008 at 15:22 (5,830 days old) by varicyclevoice (Davenport, Iowa)   |   | |
Hello guys, I have two KitchenAid dishwashers that spray a fine mist coming out from the motor underneath when it is running. I know that the shaft seal needs to be replaced. I have read my servicing manual thoroughly. Can anyone tell me which size of "o" ring to use on the motor seal? It doesn't give the measurement or thickness in the service manual. Also, are the shaft / drain impeller seals available? Can I find something at the local hardware store or do I have to order from KitchenAid? The manual says one seal is stationary and the other rotates. Thanks guys! |
Post# 278117 , Reply# 1   5/3/2008 at 16:06 (5,830 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 278126 , Reply# 3   5/3/2008 at 17:39 (5,830 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 278141 , Reply# 5   5/3/2008 at 19:47 (5,830 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Don't forget the environment. Kneeling in spilled alcohol (or worse) while the bartenders walk around, over or thru you. Listening to demands for you to 'get a move on it', getting little thanks when done but LOTS of bitching about the time/labor spent from the same owner who earlier said 'I have to have it fixed no matter what it costs...'. Then crawling back into your service rig, smelling like you rolled in the bar drip tray at a Animal House toga party from Hell... That and cleaning out Crisco like grease build up from inside a Wells fry head assy just so you can even SEE the backside of the thermostat... Nope... I do not miss my commercial service days although I did LEARN alot from them... RCD |
Post# 278155 , Reply# 6   5/3/2008 at 21:06 (5,830 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 278293 , Reply# 8   5/4/2008 at 19:10 (5,829 days old) by varicyclevoice (Davenport, Iowa)   |   | |
Post# 278323 , Reply# 9   5/4/2008 at 20:03 (5,829 days old) by bobbyderegis (Boston)   |   | |
Wow! I had no idea Hobart still made parts for their home dishwashers. Do they make the parts for the 20 and 21 series KD's? Bobby in Boston |
