Thread Number: 16907
Question for the Maytag experts |
Post# 278827 , Reply# 1   5/7/2008 at 10:47 (5,830 days old) by coldspot66 (Plymouth, Mass)   |   | |
Hey Bobby, Try spraying the motor switch with contact cleaner. I'm sure you've checked the belts and motor carriage. Also make sure the speed selector buttons are fully depressed.Depending on where it is plugged in, maybe a low voltage scenario? |
Post# 278837 , Reply# 2   5/7/2008 at 12:32 (5,830 days old) by bobbyderegis (Boston)   |   | |
Hi John! I knew you would be one of the ones to the rescue. It is definitely not a low voltage issue, not belts or motor carriage either. Would it be worth changing the switch to see if that solves the problem? Bobby in Boston |
Post# 278841 , Reply# 3   5/7/2008 at 12:57 (5,830 days old) by coldspot66 (Plymouth, Mass)   |   | |
Does this strange sound happen on any cycle; wash and spin;high and low speed? It would be worth changing the motor switch...good place to start anyway. Do you have a good switch from another motor? If not, give me the part # and I'll check it out. |
Post# 278885 , Reply# 4   5/7/2008 at 19:39 (5,829 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Can you describe the noise? That might help. One way to check the motor is to remove the wiring from the start switch and run a jumper cord to it and plug it in, eliminating the washer electronics. The test cord is easy enough to make and I'll post a chart for you. If the colors on the start switch don't match the diagram, refer to your schematic that is either in the console or stuck to the machine somewhere... This is, of course, if you're comfortable doing this. You can test with or without the belts on... RCD |
Post# 278977 , Reply# 5   5/8/2008 at 11:59 (5,829 days old) by bobbyderegis (Boston)   |   | |
Thanks RCD. I think the motor is fine. I am suspect of the switch however. I think the easiest thing to do at this point is replace the switch and see if that does the trick. Bobby in Boston |
Post# 279147 , Reply# 6   5/9/2008 at 15:40 (5,828 days old) by bobbyderegis (Boston)   |   | |
OK, Can someone translate the old part numbers into the new? The motor is 2-1666-13. The number on the switch is 8824. It seems the part numbers have changed, and some of the switches are NLA. Any suggestions? John??? Bobby in Boston |
Post# 279163 , Reply# 7   5/9/2008 at 17:26 (5,828 days old) by coldspot66 (Plymouth, Mass)   |   | |
Latest part # for motor switch is 206505....says NLA...I might be able to find one, if you want...let me know. |
