Thread Number: 16937
Timer needed for Performa dryer |
Post# 279166   5/9/2008 at 18:03 (5,801 days old) by jaytag (Atlanta)   |   | |
Hello out there. I am looking to find a timer for a PYE2200AYW dryer Maytag Performa. The cheapest online I found was $77.50. Anyone have another source possibly? Thanks Jay |
Post# 279170 , Reply# 1   5/9/2008 at 18:19 (5,801 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 279907 , Reply# 3   5/13/2008 at 17:20 (5,797 days old) by redcarpetdrew (Fairfield, CA)   |   | |
The timer on that dryer can turn both directions. I'd look at the shaft of the timer knob to make sure it isn't split and the little metal spacer sleeve is in there to prevent slop. Otherwise, if the timer itself is incredibly difficult to turn, you most likely have a timer issue and will have to replace it. There is a separate temp control switch (P/N 31001449) for hi/low/no heat. I'll include a schematic below if it helps. RCD |
Post# 279977 , Reply# 4   5/13/2008 at 21:45 (5,797 days old) by jaytag (Atlanta)   |   | |
Thank you RCD. |
