Thread Number: 17040
OH NO! NOT THE CALYPSO!!!!!!! |
Post# 280927 , Reply# 5   5/20/2008 at 14:06 (5,817 days old) by dadoes (TX, U.S. of A.)   |   | |
The pump seems to be in control of the starting/stopping. Periods when the pump stays on long enough, nutation also gets going. Maybe a bad motor board? The pump motor has a thermal overload, if it has bad bearings and is overheating, it'd likely stay off for longer periods. Same for the main drive motor. Did you keep the motor board from the trashed machine to swap-in? |
Post# 280971 , Reply# 7   5/20/2008 at 20:15 (5,817 days old) by dadoes (TX, U.S. of A.)   |   | |
Well, of course the pump isn't really controlling anything ... it's just the most obvious signal that the controller board is turning the motor outputs repeatedly on/off. Isn't the lid switch, as that would require pressing start to continue. The board fuse obviously is OK or nothing would run at all.
Post# 280998 , Reply# 9   5/21/2008 at 06:33 (5,817 days old) by jaxsunst ()   |   | |
BTW, Andrew, It was on Rinse. It is now doing it all the time. |
