Thread Number: 17047
Atlantis Help Unbalanced Load |
Post# 281023 , Reply# 2   5/21/2008 at 09:43 (5,815 days old) by laundromat (Hilo, Hawaii)   |   | |
The Maytag Atlantises had no shipping straps.They were shipped on a plastic pallet that had to be removed from the bottom and had a collar made of styrafoam that kept the tub form shifting or shaking.Because they spin with the water in the tub,the load(especialy if it isn't full or consists of area rugs or bedspreads)shifts to one side causing the off ballance spin.Try doing larger,more mixed loads. |
Post# 281047 , Reply# 3   5/21/2008 at 12:29 (5,815 days old) by redcarpetdrew (Fairfield, CA)   |   | |
1) Check your snubber ring. This little creature sits between the wash mech and the base of the washer. If the ring is too worn and/or the base of the washer where the ring rubs against is contaminated, the mech will grab the base and transfer vibration. Remember, the Dependable Care Maytags use lubricated pads while your Norge/Magic Chef made Maytag (born in Herron, IL.) uses a DRY nylon/teflon ring. 2) Check your rear leveling legs! This is the simplest thing to check. The rear legs work on a see-saw kind of arrangement about the same as a Whirlpool washer and they can easily jam. Tip the washer towards you. You should see and hear the rear legs move and when you set it back down, hear the clunk of the rear legs self adjusting to the floor. RCD |
