Thread Number: 17505
Interrupted Spin |
Post# 286562   6/22/2008 at 15:25 (5,780 days old) by bajaespuma (Connecticut)   |   | |
Post# 286575 , Reply# 1   6/22/2008 at 17:05 (5,780 days old) by appnut (TX)   |   | |
Post# 286740 , Reply# 3   6/23/2008 at 09:31 (5,779 days old) by bajaespuma (Connecticut)   |   | |
If the pressure switch allows the timer motor to run, how can it run continuously? and, if I'm missing something here, and I am, what advances the timer once all the water has been pumped out and the pressure switch opens? Also, what were those two or three holes in the middle of the tub(sort of corresponding to the ring on the activator)for ? |
Post# 286747 , Reply# 4   6/23/2008 at 09:55 (5,779 days old) by appnut (TX)   |   | |
Post# 286829 , Reply# 5   6/23/2008 at 17:00 (5,779 days old) by bajaespuma (Connecticut)   |   | |
Post# 286846 , Reply# 6   6/23/2008 at 18:33 (5,779 days old) by rickr (.)   |   | |
My guess would be because of a change in the timer, that would over ride the pressure valve for the rinse cycle. There should be no reason for the machine to pause for suds on a rinse cycle anyway. I do not know anything about the 1950's GE's, but I do know that Tom knows the old machines very well. If he said this were the way this machine was designed, I would take that as fact. |
