Thread Number: 17672
JCPenney Washer |
Post# 288788   7/5/2008 at 12:30 (5,765 days old) by trainguy (Key West, FL)   |   | |
Post# 288789 , Reply# 1   7/5/2008 at 12:30 (5,765 days old) by trainguy (Key West, FL)   |   | |
Post# 288790 , Reply# 2   7/5/2008 at 12:48 (5,765 days old) by appnut (TX)   |   | |
Post# 288801 , Reply# 3   7/5/2008 at 15:21 (5,765 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 288804 , Reply# 5   7/5/2008 at 15:27 (5,765 days old) by goblue ()   |   | |
i had a JCpenny dryer for a couple years. was a ok dryer (think the element was going bad) ended up leaving it for the new owners of the house. my friend still has a JC Penny TV for his Wii |
Post# 288811 , Reply# 6   7/5/2008 at 17:06 (5,764 days old) by gyrafoam (Wytheville, VA)   |   | |
Well, I thought you were going to tantalize us with a Penncrest solid-tub! That agitator could sure stir up the sudz! Makes me want to run a load with Viva just to see the sudz-cake! Thanks for sharing the photos! |
Post# 288832 , Reply# 7   7/5/2008 at 20:20 (5,764 days old) by filterflo (Chicago Area)   |   | |
Looks like you are on a roll Rich.......dryers dryers popping out everywhere! BTW, How is Mr S. doing? Does he need his heard thinned out again? |
Post# 288864 , Reply# 9   7/5/2008 at 22:16 (5,764 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
These were water-hogs, but most of the automatics of this time were. It would have used relatively the same amount of water as any other GE-Hotpoint of the same time. The water level would equalize between the inner and outer tubs as it was filling. The solid tub GE had a sediment hole under the agitator and one small one on the side of the tub combined with the constant overflow over the top of the tub that fed the filter-flo to keep the washtub full. If you stop the washer to soak for a while the water will eventually run out of the two small holes in the tub and equalize the levels in both.
Post# 288866 , Reply# 10   7/5/2008 at 22:22 (5,764 days old) by eddy1210 (Burnaby BC Canada)   |   | |
Post# 288928 , Reply# 12   7/6/2008 at 06:03 (5,764 days old) by laundromat (Hilo, Hawaii)   |   | |
