Thread Number: 17778
Kitchenaid Superba on Craig's List
Post# 290042   7/11/2008 at 21:30 (5,757 days old) by stevet (West Melbourne, FL)
Here is one in Jacksonville that someone might get for a song and a dance! All three for $125.00!
Dishwasher may be worth it for that price!
CLICK HERE TO GO TO stevet's LINK on Jacksonville Craigslist
Post# 290365 , Reply# 1   7/13/2008 at 12:44 (5,755 days old) by stevet (West Melbourne, FL)
Sorry, I snagged it mysel!
I just could not resist it!
This will be the first machine I have ever paid for! Got him down to 25 bucks and I will pick it up. Says it is in good condition..as long as the control panel looks good I could really care less how the rest of it is! Got enough donor machines anyway!
It happens to be a KDM-21 Monterrey model same as the Superba!
Post# 290754 , Reply# 2   7/14/2008 at 20:00 (5,754 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)
Hey Steve
toploader55's profile picture
Nice find. I'm going to run the KD2-P tonight. Got to get alot of use out of that drain valve before it rusts. Thanks again. Keep your eye out for a "Electra" or something good for YouCrate. LOL Eddie.
Post# 290763 , Reply# 3   7/14/2008 at 22:02 (5,754 days old) by mark_usa ()
Congratulations Steve
What are your plans for the control panel ? Fix another machine ? Build out one of your donor machines ?
Where will the resulting machine go ?
regards
Mark
Post# 290884 , Reply# 4   7/15/2008 at 17:25 (5,753 days old) by stevet (West Melbourne, FL)
As the HydroSweep turns!
Ed, you know full well that the drain valve will probably outlast you and I on your KDP-2. As always, use them all in good health. I have to get up there to sample some of the huge meals you seem to be cooking all the time to get your machines loaded up so much.
Mark, I am hoping to use the complete machine as is. If it turns out to be in great condition, I will probably just swap it with the KDS20 I have now. Like I said, if the control panel is good, I may just pull the door and motor and all the wiring and throw it on to the 20 tank like I have been doing all these years. We have ceramic tile from the kitchen to the garage and I hate to scrape it anywhere it may have to go. I usually place cardboard under the machine and slide it out but those older units like the 20 weigh well in excess of 125 lbs so they dont slide easily.
I will let you all know what the story is when I get back from AZ next week and pick it up on my way home form the Jacksonville airport.
Meanwhile how are you doing with your parting out sales?
Post# 290897 , Reply# 5   7/15/2008 at 19:11 (5,753 days old) by andrewinorlando ()
I want it, I want it!! If it works, I want it!!! It's a perfect 21! And it would look sooooo nice in my new kitchen!!
Post# 290906 , Reply# 6   7/15/2008 at 20:54 (5,753 days old) by 7080swashertalk ()
Great Deal!! 3 for $125. Wow!
Post# 291122 , Reply# 7   7/16/2008 at 21:38 (5,752 days old) by stevet (West Melbourne, FL)
Piece by piece
I contacted the seller and made an offer on only the dishwasher and he took it so I am taking the machine. I have no current need for a new wall oven though I will check it out if I have a chance and I don't need the range top as I have a Downdraft unit now and it is white!
Andrew, that Monterrey would look great in the new kitchen! The understated elegance of the black control panel would look great with your black panels too! Your Selectra is slick but the 21 has that classic look to it. We will see when I get it home what the story is! 'Til then, we both have to sit on pins and needles!
Post# 291218 , Reply# 8   7/17/2008 at 11:10 (5,751 days old) by andrewinorlando ()
Steve - The Monterrey was a Superba, right? Do you know what the cycle sequence was? Mostly, how long was the main wash on it? Inquiring minds want to know! And did it have 2 rinses? Yes, it would look fabulous in my new kitchen!! It does have that classic KA style, with a more contemporary flair.
Post# 291318 , Reply# 9   7/17/2008 at 21:51 (5,751 days old) by stevet (West Melbourne, FL)
Cycles and Cycles!
Andrew, the Monterrey and Superba were the same machines with slightly different styling to them.
The cycle chart looks like this for Normal Full cycle:
Prewash w heat(delayed to 140 Deg. and det 7 minutes
Drain
Purge fill
Drain
Fill for rinse 3 minutes
Drain
Fill 2nd wash w heat/ det 6 minutes
Drain
Purge Fill
Drain
Fill for rinse looks like 6-7 minute
then drain, dwell, drain and dry
Now the service manual states after rinses not a single rinse so I would hope it would somehow manage to get a second rinse in there. The user manual states the same thing about multiple after rinses!
But it could be one. Someone who has a 21 Superba will need to verify it for me. I dont recall if my aunt with the Monterrey or my Uncle with the Superba had multiple rinses.
I am sure someone will tell us!
Post# 291568 , Reply# 10   7/19/2008 at 08:36 (5,749 days old) by andrewinorlando ()
Steve - that's very similar to the 22 Superba, or the same, really. Does Soak and Scrub just add the heated pre-wash cycle? I think that washes for 6 minutes also.
I'm finding that I'm getting very good results with the 22 using Finish/Electrasol powder, rather than an enzyme detergent. Even pots and pans are substantially cleaner, which is what I expected from this machine. I guess the cycle times really are too short for an enzyme detergent to work effectively?
Post# 293893 , Reply# 11   7/31/2008 at 21:26 (5,737 days old) by stevet (West Melbourne, FL)
Well, it is in the garage !
I got the machine last week on my way back from the Jax Airport and it is actually in decent shape but needs a good deliming and cleaning. I found the jet dry dispenser cap molded to the sump in a lime deposit so the door is stained under the disopenser and the dispenser is probably trash. I will look it over and run it this weekend and update you all on it.
I will post these pics as the befores and hopefully the afters will be alot better!
Post# 293894 , Reply# 12   7/31/2008 at 21:28 (5,737 days old) by stevet (West Melbourne, FL)
front of unit
looks worse than it is.
Post# 293896 , Reply# 13   7/31/2008 at 21:29 (5,737 days old) by stevet (West Melbourne, FL)
next
how stupid could the operator be to not have looked for the cap to the dispenser?
Post# 293897 , Reply# 14   7/31/2008 at 21:31 (5,737 days old) by stevet (West Melbourne, FL)
money shot?
even the racks are dirty but absolutely pristine..no rust, chips or broken tines. Just a small section of the China guard is missing but I have lots of extras! LOL
Check out the lime on the element and fine filter!
Post# 293898 , Reply# 15   7/31/2008 at 21:32 (5,737 days old) by stevet (West Melbourne, FL)
Miracles maybe?
Think I can get it to shine again?
Post# 293899 , Reply# 16   7/31/2008 at 21:33 (5,737 days old) by stevet (West Melbourne, FL)
last one!
Yuck!
Post# 293912 , Reply# 17   7/31/2008 at 22:39 (5,737 days old) by gansky1 (Omaha, The Home of the TV Dinner!)
gansky1's profile picture
That's probably the worst I've ever seen - and I thought we had hard water here. It looks like sand and pebbles from the tap there!
The racks have been petrified by a protective layer of scale (rock) so it will be interesting to see what can be done with them. That dishwasher cleaner works miracles though, it can be done. The tank however... Perhaps you should just chisel an epitaph in the bottom and let it go to appliance heaven.
Post# 293919 , Reply# 18   7/31/2008 at 23:17 (5,737 days old) by jons1077 (Vancouver, Washington, USA)
WOW!!!
jons1077's profile picture
I wonder if dumping a bunch of vinegar in there would get most of that out. I know I bought a bakelite agitator on ebay a while back that was completely white because it was caked with lime deposits. I soaked it over night for a couple of nights in vinegar. It eventually turned that lime into a paste and it wiped right off.
I know you can clean this machine up and it'll look good as new again. It looks really nice.
Jon
Post# 294090 , Reply# 19   8/1/2008 at 18:59 (5,736 days old) by stevet (West Melbourne, FL)
Racks aren
Actually, the racks are just covered in what almost looks like dried out black mildew. Oh yeah lets just wash the dishes right now!
I hope to get to it this weekend and will be using the Dishwasher Clean stuff jet dry puts out. I dont want to use anything really harse as I dont want to etch the porcelain. I think it may just shine up nicely.
Worst case will be take all the innards and put them into my 20 tank and make a 21 daily driver!
Been using that same tank for years with many different models' mechanicals being used!
Stand by for some more pics if I get to it!
Post# 294101 , Reply# 20   8/1/2008 at 19:59 (5,736 days old) by lasvegasrox ()
ooh clean it with
this is like my favourite.I use it to get the calcium out of out stainless steel dishwasher i just let it soak for about an hour should be fine and then i run it on the longest cycle possible :)
Post# 294175 , Reply# 21   8/2/2008 at 10:22 (5,735 days old) by stevet (West Melbourne, FL)
where
Do I buy it? Who sells it?
Let me know!
Post# 294208 , Reply# 22   8/2/2008 at 18:00 (5,735 days old) by lasvegasrox ()
ooh yha
i should mention that you could buy it at target and walmart or you could order it online about 5 dollars on amazon
CLICK HERE TO GO TO lasvegasrox's LINK
Post# 294214 , Reply# 23   8/2/2008 at 20:21 (5,735 days old) by stevet (West Melbourne, FL)
Progress report!
Okay ran a complete cycle with dishwasher magic and kept returning the drain water to the tank. Definitely got rid of the soap residue not too good on the lime but did loosen alot of it. Now running Cascade Total action in it as well clean water for each cycle segment and it is loosening the black stuff on the racks. The door is getting clean and the machine is fairly quiet, though the classic Kitchenaid motor/pump sound is still there even though it has the Emerson motor. Only thing that seems to need fixing is the heater element in the blower. Not getting hot at all. Well, have to have something to do tomorrow!
Also want to double check the sump heater. seems like it should be drawing more than 10 amps. But I did not measure the actual input voltage.
Updates to follow.
Post# 294222 , Reply# 24   8/2/2008 at 21:22 (5,735 days old) by andrewinorlando ()
Steve- what about just using CLR to clean the lime and scale? I find that stuff works miracles.
Post# 294379 , Reply# 25   8/3/2008 at 18:39 (5,734 days old) by stevet (West Melbourne, FL)
Don't Watch Tool Time before wrking on any machine!
I was inspired by Tim on Home Improvement and attacked the Monterrey!
I decided to use the Muriatic Acid treatment rather than waiting for anything else to work.
Andrew, the CLR worked on the door where there was light accumulation but did nothing to the sump or strainer.
Well, I tried the muriatic acid and it worked!
Only problem was what splashed onto the fine strianer ate thru it but almost all the scale is gone! Alot of it was soap too so the fumes were really bad.
I mixed the acid with about a gallon of water and ran the pump and the washarms unclogged nearly immediately,
Now I will have to use one of my spare pump tops!
Looks like it is shaping up. Pics to follow! Shortly
Post# 294404 , Reply# 26   8/3/2008 at 20:26 (5,734 days old) by stevet (West Melbourne, FL)
Well it is done!
Here are the after pics of the Monterrey. It came out damned good if I must say so myself!
Post# 294405 , Reply# 27   8/3/2008 at 20:26 (5,734 days old) by stevet (West Melbourne, FL)
next
here is another
Post# 294406 , Reply# 28   8/3/2008 at 20:27 (5,734 days old) by stevet (West Melbourne, FL)
next
keep the cards and pictures coming!
Post# 294407 , Reply# 29   8/3/2008 at 20:28 (5,734 days old) by stevet (West Melbourne, FL)
another
next
Post# 294408 , Reply# 30   8/3/2008 at 20:29 (5,734 days old) by stevet (West Melbourne, FL)
next
getting tired yet?
Post# 294409 , Reply# 31   8/3/2008 at 20:30 (5,734 days old) by stevet (West Melbourne, FL)
maybe just one more!
sorry for the long list!
Post# 294410 , Reply# 32   8/3/2008 at 20:33 (5,734 days old) by andrewinorlando ()
Damn it looks like a brand new machine!! Aren't there internal components that the acid could harm though? Would that type of treatment be safe for the pump and seal? I used that stuff on the pool's tile grout, and that stuff would just dissolve.
Post# 294411 , Reply# 33   8/3/2008 at 20:33 (5,734 days old) by swestoyz (Cedar Falls, IA)
swestoyz's profile picture
Wow - unbelievable. I must say, some determination and a few beers can go a long way!
Ben
Post# 294413 , Reply# 34   8/3/2008 at 20:38 (5,734 days old) by tlee618 ()
Steve that is amazing, it looks like a new machine!!!
Post# 294414 , Reply# 35   8/3/2008 at 20:40 (5,734 days old) by stevet (West Melbourne, FL)
well so far so good
Just finished running 2 complete cycles, Andrew, one with detergent and one without and no leaks in the pump.
I did mess up one section of the fine strainer by getting undiluted acid on it. I put in maybe a half quart of acid to about a gallon of water and let it pump thru for about a half hour or so and these were the results! I will change out the pump top in a day or two.
Remember, the shaft seals are made to withtand the chemicals in the detergents as well as an occasional Lime a Way treatment. The seals are the same material as on the commercial units.
And it was simply determination and no beers! Hate the taste.
Now to decide what to do with it and soon!
This and the others may be all up for sale soon!
