Thread Number: 17780
KDS-15 heater removal |
Post# 290060 , Reply# 1   7/11/2008 at 23:44 (5,758 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
You shouldn't have any trouble getting it out, with the power turned off, remove (and mark if necessary) the wires on the left side of the heater unit then just remove the two phillips head screws and it should pull down from the tank with no trouble. Here is a quick pic of my KDS-15 in the garage. Work safe and good luck! |
Post# 290785 , Reply# 3   7/15/2008 at 05:39 (5,755 days old) by whitekingd ()   |   | |
The motor appears to be at the very front of the machine, correct? The KDS-14 is toward the rear of the machine. This looks much easier to service. Thank you all! |
