Thread Number: 17854
Back to Finish the GE Clothes Conditioner........ |
Post# 291186   7/17/2008 at 08:28 (5,760 days old) by filterflo (Chicago Area)   |   | |
A busy work schedule did now allow for much free time to finish the GE dryer........The later model motor I had would not fit the motor tray......so I had to re-engineer the bad motor start switch......... |
Post# 291190 , Reply# 2   7/17/2008 at 08:33 (5,760 days old) by filterflo (Chicago Area)   |   | |
Re-configured start switch........with screws instead of rivets........ |
Post# 291191 , Reply# 3   7/17/2008 at 08:35 (5,760 days old) by filterflo (Chicago Area)   |   | |
Re soldering the switch back to the motor winding........I also always draw a picture of what Im working on, so that I dont forget what goes where. This is especially helpful when you wait 2 or 3 weeks between repairs! |
Post# 291192 , Reply# 4   7/17/2008 at 08:36 (5,760 days old) by filterflo (Chicago Area)   |   | |
Re-installed motor switch, back in place on the motor cover.... |
Post# 291193 , Reply# 5   7/17/2008 at 08:38 (5,760 days old) by filterflo (Chicago Area)   |   | |
I also mark (with white out) lines on the motor bearing plates so that they can be installed back in their same location. This often helps when putting the motor back together and also with the alignment of the bearings back to their original position........ |
Post# 291195 , Reply# 6   7/17/2008 at 08:39 (5,760 days old) by filterflo (Chicago Area)   |   | |
Motor back in its mount and re-installed back in the dryer. Im NOT going any further now UNTIL I know it works! |
Post# 291196 , Reply# 7   7/17/2008 at 08:41 (5,760 days old) by filterflo (Chicago Area)   |   | |
Temporarily reconnect the front panel for the door switch, light, and compensated control wires.......and then give it a fast test to make sure the motor works AND the heat and lights come on........... |
Post# 291197 , Reply# 8   7/17/2008 at 08:42 (5,760 days old) by filterflo (Chicago Area)   |   | |
YEAH! Success!!! It all works.........breathe a sigh of relief>........ |
Post# 291198 , Reply# 9   7/17/2008 at 08:43 (5,760 days old) by filterflo (Chicago Area)   |   | |
All back together, and now ready for another 48 years of faithful service!........ |
Post# 291205 , Reply# 10   7/17/2008 at 09:27 (5,760 days old) by pdub (Portland, Oregon)   |   | |
Post# 291307 , Reply# 12   7/17/2008 at 20:22 (5,760 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
