Thread Number: 17887
Re: Maytag Portable Dishwasher Help Please: |
Post# 291786 , Reply# 1   7/20/2008 at 15:31 (5,756 days old) by redcarpetdrew (Fairfield, CA)   |   | |
It sounds more like you have a water spray issue. You may need to check your wash arm spray holes. If they are plugged, the water will not properly wash the detergent out of the cup. Also, make sure your wash arms are TURNING easily, esp. the lower. You may have to dis-assemble the upper pump housing to clean the hub and possible self-cleaning filter assy and back wash arms. Also, make sure you have enough water in the tub to do the job. When the float switch is satisfied, I believe the water should be right below if not touching the heating element. Good Luck! RCD |
Post# 291797 , Reply# 2   7/20/2008 at 17:17 (5,756 days old) by sactoteddybear ()   |   | |
Hi! RCD, I've written you an E-Mail with some more info. Peace and hopefully a happy Maytag Dishwasher Neighbor soon, Steve SactoTeddyBear |
Post# 292695 , Reply# 3   7/26/2008 at 13:19 (5,750 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 292734 , Reply# 4   7/26/2008 at 17:26 (5,750 days old) by sactoteddybear ()   |   | |
Hi! RCD, I did get you recent E-Mail, thank you for you help and advise. Peace and Kind Regards, Steve SactoTeddyBear... |
Post# 292830 , Reply# 5   7/27/2008 at 04:23 (5,750 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 293135 , Reply# 7   7/28/2008 at 12:52 (5,748 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
