Thread Number: 17960
Maytag Portable Dishwasher Problems |
Post# 292686 , Reply# 1   7/26/2008 at 12:31 (5,751 days old) by coldspot66 (Plymouth, Mass)   |   | |
Beneath the pump cover there is a circular mesh filter. If it's clogged with food it will not let the water flow to the wash arm. Also check to see that the wash impeller is tight to the shaft of the motor. |
Post# 292691 , Reply# 2   7/26/2008 at 13:12 (5,751 days old) by redcarpetdrew (Fairfield, CA)   |   | |
while you're checking the filter, make sure the backwash arm (a 4 legged affair) is clean at the ends where water sprays out to clean the filter assy. Make sure the spray jets on the wash arms are clean and the wash arms turn freely. This is a portable model and is dependent on good pressure from the faucet. The ideal water level is when the water level in the tub is just below or just touching the circular heating element. If it isn't, you don't have enough water to properly wash. If you want, I can post a breakdown of the wash system to assist your teardown. Just let me know. By the way, your dishwasher can be converted to a built in with a kit if you ever wanted to cabinet mount it. RCD |
