Thread Number: 17964
Frigidaire Rollermatic Question |
Post# 292731 , Reply# 1   7/26/2008 at 17:14 (5,751 days old) by easyspindrier (Maryland)   |   | |
Here's the wire connector block picture. |
Post# 292737 , Reply# 2   7/26/2008 at 17:42 (5,751 days old) by pdub (Portland, Oregon)   |   | |
On each top corner in the front there are two spring clips. Stick a paint scraper between the edges taking care not to scratch the finish and push in on each clip one at a time. Lift the edge slightly then do the same to the next one. Then you can lift up on it and the whole top will slide forward about an inch and you'll be able to see how everything moves. The harness clip has two tabs on each side that you can probably get to release with a very small screwdriver, but be careful as 40+ year old plastic can be very brittle and you don't want to break anything. I hope this helps you. Patrick |
