Thread Number: 17975
a104 Maytag Help please |
Post# 292977 , Reply# 1   7/27/2008 at 20:01 (5,750 days old) by volvoguy87 (Cincinnati, OH)   |   | |
Is this a Center-Dial Maytag? IF I am right (and I may not be) the leak may be an easy fix. In the back left corner of the machine, at the top, there is the injector. This is a system of tubes that fills the tub with water. Other people here are much more knowledgeable than me, but I think you clean some tubes and maybe replace 1 or two (not expensive) to fix the leak. As for the non-functioning washer, did a circuit breaker flip or did a GFCI trip? Let it dry out for a few days and try turning on the washer in the spin cycle. This will test if the motor turns on without any water coming in contact with the washer at all. Please wait for someone else to reply before taking my advice, however. Good luck, Dave |
Post# 293190 , Reply# 2   7/28/2008 at 17:11 (5,750 days old) by goatfarmer (South Bend, home of Champions)   |   | |
