Thread Number: 18087
GE V-12 Washer ?'s |
Post# 294412 , Reply# 1   8/3/2008 at 20:36 (5,743 days old) by tlee618 ()   |   | |
Oh my that is one beautiful machine, I sure hope you find a new tub for it!! Could you share some of the machines history with us? |
Post# 294416 , Reply# 2   8/3/2008 at 20:55 (5,743 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 294490 , Reply# 4   8/4/2008 at 06:34 (5,743 days old) by bajaespuma (Connecticut)   |   | |
GE washers had no drain solenoid. If the drain hose was cut off of the machine at the pump valve, which is often the case when these machines are left for dead, you have to get a drain hose and loop it up to the top of the tub before you attach another drain hose extension or the water will just flow out of the pump and then out of the machine.
Post# 294492 , Reply# 5   8/4/2008 at 06:40 (5,743 days old) by bajaespuma (Connecticut)   |   | |
Post# 294497 , Reply# 6   8/4/2008 at 06:53 (5,743 days old) by bajaespuma (Connecticut)   |   | |
Post# 294539 , Reply# 8   8/4/2008 at 11:31 (5,743 days old) by roto204 (Tucson, AZ)   |   | |
Post# 294670 , Reply# 10   8/4/2008 at 18:26 (5,742 days old) by goatfarmer (South Bend, home of Champions)   |   | |
