Thread Number: 1866
Maytag A606-problems with owner |
Post# 63759 , Reply# 1   4/20/2005 at 10:13 (6,938 days old) by maytagmom ()   |   | |
My picture I uploaded didn't post w/my message :-( |
Post# 63766 , Reply# 2   4/20/2005 at 11:15 (6,938 days old) by fixerman ()   |   | |
To access the lid switch, remove the screws from the brackets that attach the console face to the top. This should give you easy access to the lid switch. |
Post# 63788 , Reply# 4   4/20/2005 at 17:54 (6,937 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Maytagmom,the lid switch is held in place by two screws,with 1/4 inch heads on them.Sometimes you can loosen them with a long 1/4" nutdriver.If not,there are 4 screws that hold the console to the top. They also have 1/4" heads,two on each side of the console,that go into the top of the washer.Remove them,the console then can be moved forward,to access the lid switch.Let us know if you need more info. kennyGF |
