Thread Number: 18726
KUDS220T4(will not drain) |
Post# 303718   9/15/2008 at 09:26 (5,673 days old) by gadgetgary (Bristol,CT)   |   | |
Post# 303820 , Reply# 1   9/15/2008 at 17:13 (5,673 days old) by bobbyderegis (Boston)   |   | |
Gary: Sounds like the drain solenoid. It should be an easy fix. Bobby in Boston |
Post# 303826 , Reply# 2   9/15/2008 at 17:36 (5,673 days old) by coldspot66 (Plymouth, Mass)   |   | |
Hi Gary, Can you get it to wash.....or is there any motor sound at all?? |
Post# 303836 , Reply# 4   9/15/2008 at 18:53 (5,673 days old) by stevet (West Melbourne, FL)   |   | |
With Coldspot. Also make sure that the wiring harness to the motor is intact and tight. Dont forget to check the wires on the start relay too. We need to know if it runs in reverse(drain) so we can suggest other possibilities. Let us know! |
Post# 303880 , Reply# 5   9/15/2008 at 20:57 (5,673 days old) by gadgetgary (Bristol,CT)   |   | |
Post# 304446 , Reply# 8   9/18/2008 at 08:52 (5,670 days old) by gadgetgary (Bristol,CT)   |   | |
Post# 304447 , Reply# 9   9/18/2008 at 09:08 (5,670 days old) by gadgetgary (Bristol,CT)   |   | |
Post# 304464 , Reply# 10   9/18/2008 at 13:05 (5,670 days old) by peteski50 (New York)   |   | |
Post# 304513 , Reply# 13   9/18/2008 at 22:01 (5,670 days old) by stevet (West Melbourne, FL)   |   | |
Gary and Brent, if Brent cant get to it,I wouldnt mind parting my current daily driver 20 out to you! Gives me an excuse to install the KDS21M I have in the garage that I showed on here a few weeks back! Keep me posted! |
Post# 304588 , Reply# 14   9/19/2008 at 11:45 (5,669 days old) by a440 ()   |   | |
Hello guys, I checked. The the dishwasher I have is a KUDS21. Steve...is that the same timer as the KUDS22? Brent |
Post# 304737 , Reply# 17   9/20/2008 at 07:00 (5,668 days old) by stevet (West Melbourne, FL)   |   | |
IIRC, the 22 added the "Quick Glass" cycle to it's options. It also had buttons all the way across the right side where the 21 had the space between the set of 7. 3 space 4 setup! I am ready to stand corrected on that one! Steve |
Post# 305430 , Reply# 18   9/24/2008 at 14:07 (5,664 days old) by gadgetgary (Bristol,CT)   |   | |
Post# 305431 , Reply# 19   9/24/2008 at 14:08 (5,664 days old) by gadgetgary (Bristol,CT)   |   | |
Post# 305432 , Reply# 20   9/24/2008 at 14:09 (5,664 days old) by gadgetgary (Bristol,CT)   |   | |
Post# 305433 , Reply# 21   9/24/2008 at 14:10 (5,664 days old) by gadgetgary (Bristol,CT)   |   | |
Post# 305502 , Reply# 22   9/24/2008 at 19:16 (5,664 days old) by andrewinorlando ()   |   | |
......on getting the baby back up and running. Would be too much like parting with an old friend.....and a pretty one at that. |
Post# 305517 , Reply# 24   9/24/2008 at 20:25 (5,664 days old) by gadgetgary (Bristol,CT)   |   | |
Post# 305533 , Reply# 25   9/24/2008 at 21:35 (5,664 days old) by toggleswitch2 ()   |   | |
.............and if no individual wants it, is there a company that repairs them (or supplies them) were it could be sent and recycled? |
Post# 305717 , Reply# 26   9/25/2008 at 20:22 (5,663 days old) by gadgetgary (Bristol,CT)   |   | |
Soak&Scrub Pots&Pans 90.5 min 12.25 gal Normal Wash 78 min 10 gal Light Wash 49.5 min 9.75 gal Quick Glass Wash 34.5 min(w dry)7.5 gal *18 min(w/o dry) Rinse & Hold 6 min 2.25 gal *Never used Quick glass much and did not realize that without the heated dry, it almose cuts the cycle time in half. The cycle starts with a rinse period, followed by one wash period with one rinse. Soak&Scub starts with a soak and scrub period, followed by two wash periods with two rinses and a dry portion. Normal Wash has two wash perids, two rinse periods and a dry portion. Light/china wash has two wash periods and two rinse periods and a dry portion. |
