Thread Number: 18818
Kitchen aid portable |
Post# 304983 , Reply# 1   9/21/2008 at 22:44 (5,692 days old) by appnut (TX)   |   | |
Post# 305012 , Reply# 2   9/22/2008 at 02:59 (5,692 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Another Regency. I just picked one up about a month or so.They clean great, but the racking gets tricky. When I'm making dinner and getting things ready, I use as many plates as possible. I'll even serve a salad on a plate because pretty much everything must be a plate in the lower rack. You can not put large mixing bowls in the lower rack Strickly for flat pieces. The only issue I had with mine was the fill solenoid strainer was jammed packed, so you might want to check that out. Eddie |
Post# 305101 , Reply# 4   9/22/2008 at 17:03 (5,691 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
