Thread Number: 18875
maytag dependablecare COIN-OP |
Post# 305893 , Reply# 1   9/26/2008 at 17:41 (5,687 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 305903 , Reply# 2   9/26/2008 at 18:45 (5,687 days old) by dave9999 ()   |   | |
model LA23CS (A23CS), sorry, dont know how to rotate schematic ! |
Post# 306157 , Reply# 3   9/27/2008 at 18:14 (5,686 days old) by toggleswitch2 ()   |   | |
Le Voila! Na to! Here it is! |
Post# 306163 , Reply# 4   9/27/2008 at 18:59 (5,686 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Some ideas... 1)You might have a timer issue 2)You might have a pressure switch issue 3)You might have a lid switch issue. When you say you 'reset the timer', did the timer make it to a off postion like it went thru a cycle, or did it stop mid cycle so you have to advance it to the beginning again? When it malfuctions, is it full or will it empty? RCD |
Post# 306235 , Reply# 6   9/28/2008 at 09:01 (5,685 days old) by coldspot66 (Plymouth, Mass)   |   | |
Sounds like a dead spot at a certain point on the timer. Is it a "box type" timer with individual wires connected, or a plug-in quick disconnect type? |
Post# 306294 , Reply# 7   9/28/2008 at 19:28 (5,685 days old) by dave9999 ()   |   | |
its plastic body timer with individual wires, lots of them on each side. Think its repairable or replace ($100 or more). |
