Thread Number: 18886
Maytag SAV2655AWW-Residue-Shut Off Faucets? |
Post# 305923 , Reply# 1   9/26/2008 at 20:30 (5,687 days old) by volvoguy87 (Cincinnati, OH)   |   | |
1st, the valves. Most people do not close the valves like they should. It is a VERY rare occurrence that the hoses fail, but when it happens, the damage can be tremendous. Using washing machine hoses with a braided metal skin reduces the risk significantly. 2nd, you should either replace the valve, or replace the washers inside. Either way, it's not too horrifying a job. Read up on it and you ought to be able to do it yourself. 3rd, white residue on your clothes. Is it an even coating or in patches? How hard is your water? It can be detergent residue because you may be using too much detergent and your water may be too hard to allow all of it to sufficiently dissolve and rinse. Try running a cycle with no clothes BUT do not use any detergent! Use hot water without detergent and if you get a bunch of suds, your washer had lots of detergent residue in it. If you want to add anything, maybe some water softener like Calgon. When washing clothes, the water should feel slippery. 4th, Your washer is not a real Maytag. The SAV series washers are actually an Amana design. Unfortunately, they do not have a great reputation and are known for being a royal pain to work on and having a weak main seal which dumps the wash water on the floor when it fails. If you can replace it with a Maytag Dependable Care with the porcelain tub, you should be good to go for a few decades. Best of luck, Dave (I had an Amanatag once and replaced it upon its demise with a Maytag A208 Center Dial from Jan. 1980 and haven't looked back.) |
Post# 306162 , Reply# 3   9/27/2008 at 18:52 (5,686 days old) by redcarpetdrew (Fairfield, CA)   |   | |
When you do the shut off valves, replace them with ball valves if possible. Ball valves are like the gas shut off valves where you just turn it 1/4 - 1/2 turn and it's off. I very seldom see them fail. I agree, stainless steel braided fill hoses are the way to go to prevent a fill hose water excursion. Unfortunately, the SAV's do have a bad rep (I've repaired quite a few that threw the main seal due to a badly milled upper trans housing) but not everyone did it. She can keep using it but watch out for the signs: A loud roar when spinning, water leakage from underneath, the washer starting to shake and walk around, etc... RCD |
Post# 306280 , Reply# 4   9/28/2008 at 17:05 (5,685 days old) by joe89 ()   |   | |
Thank you both. Is it really that bad? It says Commercial quality, Lifetime tub on the front :-) How can I find what year it is? Model SAV2655AWW Serial 14115763GC |
Post# 306315 , Reply# 5   9/28/2008 at 20:50 (5,685 days old) by coldspot66 (Plymouth, Mass)   |   | |
Step AWAY from the Amanatag.................DANGER WILL ROBINSON!!!!!!!!!!!! LOL!!!!!!!!! |
Post# 306318 , Reply# 6   9/28/2008 at 20:54 (5,685 days old) by coldspot66 (Plymouth, Mass)   |   | |
White residue could be lint...especially on dark colored clothes. I think there is a filter that sits below the inner tub on the washbasket hub....I have seen them get pretty gunked up with lint and soap scum. |
Post# 306332 , Reply# 7   9/28/2008 at 21:52 (5,685 days old) by joe89 ()   |   | |
Amanatag Washing Machine Squeak |
Post# 306337 , Reply# 8   9/28/2008 at 22:33 (5,685 days old) by volvoguy87 (Cincinnati, OH)   |   | |
That was my Amanatag not too long before it was replaced with my A208 (now residing with Calssiccaprice). I borrowed a friend's camera and filmed that to show AW.org what my problem was. The squeak only happened during agitation. The squeak was caused by the brake slipping and the tub indexing (turning during agitation) a little bit. The repairman my landlord sent over lubricated the brake pads which stopped the squeak but did nothing to stop the indexing. If I recall, these aren't supposed to index. Eventually, they replaced the snubber. It also made some truly horrifying clunking and banging during spins. Maytag had a well-deserved good reputation at the time that washer was made. Maytag washers and dryers were the best money could buy. They washed the best and lasted the longest. Unfortunately, they had a real lemon with the first series of the Neptune front loaders. They needed a larger capacity conventional washer than they had at the time and they needed it FAST! Some time prior to all this, Maytag bought Amana. Maytag simply took the larger Amana design, cheapened it, and put it into production as the SAV series. The SAV Amanatags were cheaper to produce and had a very large capacity. People thought they were high quality because they had stainless steel tubs. Sadly, they tend not to hold up at all well and don't really wash that well. At the time the Amanatags were in production, Maytag also was still making their Dependable Care line. They were smaller capacity, more expensive, and had porcelain tubs. They looked like they were lower quality and lower end washers. Looks are deceiving, however, because the Dependable Care line was the classic Maytag high-quality washing machine that built their good reputation. If possible, sell the Amanatag and get a used Dependable Care before that Amanatag floods your house. Sadly, when Whirlpool bought Maytag, they ceased production of the Dependable Care line. A used Dependable Care is better than anything you can buy new today. The closest you can get is a Speed Queen but they are very expensive (worth it though). A used Dependable Care will outlast anything by GE, Frigidaire, or Whirlpool/Kenmore/etc. (toploaders only, I HATE frontloaders). Even among new front loaders, a used Dependable Care is likely the best bargain in terms of cost vs. years of service you can expect. That Amanatag was a squeaking time bomb, glad I defused it with a real Maytag! Dave |
Post# 306353 , Reply# 9   9/29/2008 at 00:30 (5,685 days old) by joe89 ()   |   | |
All I have to say is: how's the matching dryer? :-) |
Post# 306422 , Reply# 10   9/29/2008 at 10:47 (5,684 days old) by volvoguy87 (Cincinnati, OH)   |   | |
We had the matching dryer and it was fine. Not as nice as a classic Whirlpool/Kenmore 29" with the lint screen on the top back right corner. Nor was it a classic Maytag. The Amanatag dryers have a large capacity, reasonably quick drying time, and mine even had a light in the drum which was VERY nice. Those dryers are OK and do not have the same reputation as the washers. Replace the washer, but there is absolutely no reason to replace the dryer. Besides, it takes forever to line dry clothes in the rain, Dave |
Post# 306427 , Reply# 11   9/29/2008 at 11:06 (5,684 days old) by whirlcool (Just North Of Houston, Texas)   |   | |
Oh No! Not another Amanatag! I would have thought that they'd all have failed by now... Those WP/Kenmore dryers are fantastic. We have one and the automatic settings really do a good job sensing when the clothes are dry. We bought ours in 1993 and have not had one problem with it yet. |
Post# 306579 , Reply# 13   9/29/2008 at 23:13 (5,684 days old) by whirlcool (Just North Of Houston, Texas)   |   | |
But see what happens when you try to "collect" on that warranty. |
Post# 306599 , Reply# 14   9/30/2008 at 02:27 (5,684 days old) by mayfan69 (Brisbane Queensland Australia)   |   | |
Joe, Do a search on google and you will find many complaints about these washers...maybe print some off and show your mum. Below is an example.... Leon CLICK HERE TO GO TO mayfan69's LINK |
Post# 306600 , Reply# 15   9/30/2008 at 02:28 (5,684 days old) by mayfan69 (Brisbane Queensland Australia)   |   | |
Post# 307041 , Reply# 17   10/1/2008 at 20:26 (5,682 days old) by whirlcool (Just North Of Houston, Texas)   |   | |
that the squeaky sound reminds you of a dog's squeaky toy, or of that of a woman having sex. That'll do it! |
Post# 307042 , Reply# 18   10/1/2008 at 20:28 (5,682 days old) by joe89 ()   |   | |
Right :-) I just emailed the local appliance store about it. |
Post# 307045 , Reply# 19   10/1/2008 at 20:35 (5,682 days old) by jaytag (Atlanta)   |   | |
I picked up the same style washer 2 mos ago and the washer had the same squeek, I quickly sold the pair. |
Post# 980793 , Reply# 20   1/31/2018 at 20:31 (2,273 days old) by Stricklybojack (South Hams Devon UK)   |   | |
Post# 980879 , Reply# 21   2/1/2018 at 16:53 (2,272 days old) by stricklybojack (South Hams Devon UK)   |   | |
Damn, should have sent this beast to the scrapper. I spent the morning in the hot sun trying to liberate the wash basket to use as a fire pit. It is CEMENTED in place. Still stuck, left it for another day. This thing has the cheapest shell wrapped around an incredibly substantial base. I guess the large tub size demanded HD components under the hood. That motor is a boat anchor. Given the timebomb nature of this design I doubt there is a market for any of this detritus on EBay. |
