Thread Number: 19152
Launderall -- If you think the Multimatic is complicated... |
Post# 309238   10/14/2008 at 14:22 (5,671 days old) by unimatic1140 (Minneapolis)   |   | |
I'm working on scanning the 1948 Launderall service manual for Chris and others to use. I should have the complete manual scanned and posted this evening or tomorrow Pages 3 thru 12 of the manual are particularly interesting. They show how this very first reverse-tumbling, horizontal access washer works designed like so many other early automatics, in the 1930s... |
Post# 309240 , Reply# 1   10/14/2008 at 14:24 (5,671 days old) by unimatic1140 (Minneapolis)   |   | |
Post# 309241 , Reply# 2   10/14/2008 at 14:25 (5,671 days old) by unimatic1140 (Minneapolis)   |   | |
Post# 309242 , Reply# 3   10/14/2008 at 14:25 (5,671 days old) by unimatic1140 (Minneapolis)   |   | |
Post# 309243 , Reply# 4   10/14/2008 at 14:26 (5,671 days old) by dj-gabriele ()   |   | |
I still don't understand why they didn't use a simple pulley and a two speed motor like ordinary top loading horizontal axis washers of today! |
Post# 309244 , Reply# 5   10/14/2008 at 14:26 (5,671 days old) by unimatic1140 (Minneapolis)   |   | |
Post# 309245 , Reply# 6   10/14/2008 at 14:27 (5,671 days old) by unimatic1140 (Minneapolis)   |   | |
Post# 309246 , Reply# 7   10/14/2008 at 14:28 (5,671 days old) by unimatic1140 (Minneapolis)   |   | |
Post# 309247 , Reply# 8   10/14/2008 at 14:28 (5,671 days old) by unimatic1140 (Minneapolis)   |   | |
Post# 309248 , Reply# 9   10/14/2008 at 14:29 (5,671 days old) by unimatic1140 (Minneapolis)   |   | |
Post# 309249 , Reply# 10   10/14/2008 at 14:30 (5,671 days old) by unimatic1140 (Minneapolis)   |   | |
Post# 309254 , Reply# 11   10/14/2008 at 14:39 (5,671 days old) by unimatic1140 (Minneapolis)   |   | |
I still don't understand why they didn't use a simple pulley and a two speed motor like ordinary top loading horizontal axis washers of today! Well in 1948 two speed AC motors would only have ran at 1140rpm on low and 1725rpm on high. So to make the wash tumble speed at approx 52rpm that means the spin speed wouldn't even be doubled at around 100rpm which of course wouldn't be fast enough to extract water from the clothes. They would have to employ some kind of speed shifting transmission like the Bendix and Westinghouse front loaders. But the Launderall engineers took it one step further in making a machine that reverse tumbles and does it without any electrical or electronic timing devices. |
Post# 309256 , Reply# 12   10/14/2008 at 15:06 (5,671 days old) by volvoguy87 (Cincinnati, OH)   |   | |
In historic preservation, I find that things were often done differently in the past than they are today for very good reasons. If you understand those reasons (such as motor speed limitations) some of the zaniest, Rube Goldberg designs make perfect, logical sense. A more common example... GE Filter Flo washers with a single speed motor, a transmission, AND a crazy 1, 2, 3, or variable speed clutch. Why have this complicated clutch instead of a multi-speed motor? The Filter Flo system relies on a pump for recirculation! The motor must run at 1 speed to ensure the pump operates correctly on all cycles and speeds. The only way to get multiple speeds with that type of constant speed motor and pump is to change speeds between the motor and the transmission. Presumably, a multi-speed clutch was cheaper than having several different models of transmissions with multiple speed capabilities. It makes perfect sense when you understand the logic, Dave |
Post# 309265 , Reply# 13   10/14/2008 at 15:43 (5,671 days old) by tuthill ()   |   | |
Suddenly reverse tumbling doesn't seem all that important :) |
Post# 309277 , Reply# 14   10/14/2008 at 16:22 (5,671 days old) by dj-gabriele ()   |   | |
OK, thank you! |
Post# 309311 , Reply# 15   10/14/2008 at 20:10 (5,671 days old) by a440 ()   |   | |
This is incredible! Wow! What a complex system! They did make it work however. Just sounds like it was not very reliable! I bet the engineers were having so much fun with the design of this machine! Brent |
Post# 309319 , Reply# 16   10/14/2008 at 20:38 (5,671 days old) by unimatic1140 (Minneapolis)   |   | |
Here is the full 1948 Launderall Service manual, its 60mb so it will take a minute or so to download. We definitely need more of these on this website, I will have to create a separate button from the home page with Service Manuals links. If you have some vintage washer/dryer/dishwasher service manuals, a scanner and can scan them at 150dpi and can create .pdf files, I will add them to this upcoming library. CLICK HERE TO GO TO unimatic1140's LINK |
Post# 309322 , Reply# 17   10/14/2008 at 20:49 (5,671 days old) by toggleswitch2 ()   |   | |
Would you be interested in comparative feature/sales brochures as well? |
Post# 309324 , Reply# 18   10/14/2008 at 21:01 (5,671 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 309331 , Reply# 19   10/14/2008 at 21:37 (5,671 days old) by unimatic1140 (Minneapolis)   |   | |
Post# 309334 , Reply# 20   10/14/2008 at 22:10 (5,671 days old) by volvoguy87 (Cincinnati, OH)   |   | |
I love how the forums are packed full of information on how to keep our machines alive. AW.org is the first place to which I turn when I need to fix something. Unfortunately, many issues are posted again and again because we have read about it here before, but can't remember the details, need some clarification, or can't find the archived thread. Putting some service manuals online should clear up some confusion and repetitious posts. Keep up the good work Robert, Dave |
Post# 309346 , Reply# 21   10/14/2008 at 22:46 (5,671 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 309354 , Reply# 23   10/14/2008 at 23:20 (5,670 days old) by hooverwheelaway ()   |   | |
**Giggle** |
Post# 309367 , Reply# 24   10/15/2008 at 06:15 (5,670 days old) by christfr (st louis mo)   |   | |
Post# 309369 , Reply# 25   10/15/2008 at 06:27 (5,670 days old) by christfr (st louis mo)   |   | |
the printer is still running .. gees did i ever open a can or worms ha ha.. when i had the trans cover off after i had cleaned it up in there there are no stripped gears or metal flakes everything looks good you can turn things with your fingers and watch gears move. all looked ok so i put the trans back into the machine. let it run she wants to tumble in one direction only but is running better than she did when she got here so im gonna the machine run for a few more days and see if things improve and if not well take it out again. its funny mark wants to get his hand on this machine so bad i think he can taste it
Post# 309372 , Reply# 26   10/15/2008 at 07:32 (5,670 days old) by jasonl (Cookeville, TN)   |   | |
I'd love to see the belt drive Kenmore, Maytag, and GE Filter Flo manuals get posted so when I'm ready I can start restoring my lovely machines. |
Post# 309377 , Reply# 27   10/15/2008 at 08:19 (5,670 days old) by unimatic1140 (Minneapolis)   |   | |
when i had the trans cover off after i had cleaned it up in there there are no stripped gears or metal flakes everything looks good you can turn things with your fingers and watch gears move. all looked ok so i put the trans back into the machine. Hey Chris, after you cleaned out the old grease what did you use to relubricate the transmission? |
Post# 309381 , Reply# 28   10/15/2008 at 10:04 (5,670 days old) by fredfred9633 ()   |   | |
he has his work cut out for him |
Post# 309452 , Reply# 30   10/15/2008 at 17:32 (5,670 days old) by favorit ()   |   | |
It's a sort of swiss watch !! Carlo PS: Diomede, You' d like this modern jewel too : CLICK HERE TO GO TO favorit's LINK |
Post# 309453 , Reply# 31   10/15/2008 at 17:44 (5,670 days old) by tuthill ()   |   | |
That's blasphemy. |
Post# 309458 , Reply# 32   10/15/2008 at 18:39 (5,670 days old) by saltysam ()   |   | |
LOL.........Sheez! Was it that obvious? LOL I have a hard time containing my excitment sometimes....... Mark |
Post# 309534 , Reply# 33   10/16/2008 at 06:13 (5,669 days old) by christfr (st louis mo)   |   | |
Post# 309558 , Reply# 34   10/16/2008 at 09:03 (5,669 days old) by unimatic1140 (Minneapolis)   |   | |
Post# 309696 , Reply# 36   10/16/2008 at 20:03 (5,669 days old) by launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Would be really interesting if some American appliance maker, or an investor with deep pockets would sit those "V-Zug" people down and see if they would do a deal to bring some of their appliances to the US market. However, as Miele has finally given up the ghost on 220v laundry and even dishwashing appliances in the United States, reworking the appliances to run on 120v would probably add huge R&D costs to the considerable shipping/import costs. In short, just as Miele found out, sales numbers probably wouldn't justify costs. OTHO if certian patents and design elements could be licensed and an American quasi "V-Zug" could be made in the US, along the lines of Bosch's "Nexxt" line, perhaps things could be different. L. |
Post# 309805 , Reply# 37   10/17/2008 at 06:34 (5,668 days old) by christfr (st louis mo)   |   | |
