Thread Number: 19208
Restoration Secret: Breeze Make-a-Clamp 4000 |
Post# 309887   10/17/2008 at 16:35 (5,661 days old) by unimatic1140 (Minneapolis)   |   | |
I love this product, it just saved the day once again (or so I think, will find out this weekend). With this you can make your own screw-type stainless steel water clamps of any size. Comes in real handy for making those big 11" diameter or larger outer tub water boot clamps like in a GE. You can't just run out to Ace Hardware and pick up one of those. Just thought I would pass this tip along. CLICK HERE TO GO TO unimatic1140's LINK |
Post# 309949 , Reply# 1   10/17/2008 at 21:56 (5,660 days old) by a440 ()   |   | |
Interesting Clamp! So...What did you fix??? Curious mind... Brent |
Post# 310013 , Reply# 2   10/18/2008 at 09:09 (5,660 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 310015 , Reply# 3   10/18/2008 at 09:15 (5,660 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 310041 , Reply# 4   10/18/2008 at 12:37 (5,660 days old) by roto204 (Tucson, AZ)   |   | |
Post# 310084 , Reply# 5   10/18/2008 at 19:47 (5,659 days old) by unimatic1140 (Minneapolis)   |   | |
Post# 310086 , Reply# 6   10/18/2008 at 19:47 (5,659 days old) by unimatic1140 (Minneapolis)   |   | |
Post# 310088 , Reply# 7   10/18/2008 at 19:48 (5,659 days old) by unimatic1140 (Minneapolis)   |   | |
Post# 310093 , Reply# 8   10/18/2008 at 20:21 (5,659 days old) by tuthill ()   |   | |
I wanna use this one next! Sure beats the curb ;) |
Post# 310096 , Reply# 10   10/18/2008 at 20:37 (5,659 days old) by a440 ()   |   | |
What a great invention / idea! I hope they make a million off of it. Amazing that can accommodate such a large size! Robert....did you invent this clamp? Come on...don't be modest! Brent |
Post# 310103 , Reply# 11   10/18/2008 at 21:23 (5,659 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 310134 , Reply# 13   10/19/2008 at 01:06 (5,659 days old) by alr2903 (TN)   |   | |
o, one last question please, where does the water enter, im thinking somewhere in the outer drum, as an 8 year old i only remember, the water eventually made a few streaks on the glass, then it seemed like a deluge. alr2903 |
Post# 310605 , Reply# 15   10/21/2008 at 06:15 (5,657 days old) by alr2903 (TN)   |   | |
I believe the washer spin speed is around 450 rpm and was mated with a Very hot dryer. Robert what a great job...bump.. |
Post# 310661 , Reply# 16   10/21/2008 at 12:05 (5,657 days old) by unimatic1140 (Minneapolis)   |   | |
Does your machine have white vinyl on the door? White Vinyl??? Actually its gray rubber Jon on my door. Oh, and by the way, your spin belt looks loose in your photo. (Just Kidding :) Actually it is loose Brent. The way this washer works is during wash tumble the spin belt is made to slip because its loose, during spin the spin solenoid engages which forces the two peice spin drive pulley to sqeeze together tightening the belt and drive the tub at around 450rpm. This is a washer only dj-gabriele. |
Post# 310664 , Reply# 17   10/21/2008 at 12:18 (5,657 days old) by neptunebob (Pittsburgh, PA)   |   | |
