Thread Number: 19410
Electrolux Australia Water Aid washing machine |
Post# 312535   10/31/2008 at 20:19 (5,652 days old) by ronhic (Canberra, Australia)   |   | |
Hello all... I thought that some of you may appreciate this. The idea is good. Control the amount of water leaving the inner tub to the outer tub...pump it back to the inner tub to create a higher level and therefore save water.... CLICK HERE TO GO TO ronhic's LINK |
Post# 313407 , Reply# 1   11/6/2008 at 06:41 (5,647 days old) by toggleswitch2 ()   |   | |
Interesting. Thanks for posting. |
Post# 313450 , Reply# 2   11/6/2008 at 11:32 (5,646 days old) by pdub (Portland, Oregon)   |   | |
Post# 313992 , Reply# 3   11/9/2008 at 20:00 (5,643 days old) by arrrooohhh (Sydney Australia)   |   | |
Electrolux Wateraid |
Post# 313993 , Reply# 4   11/9/2008 at 20:01 (5,643 days old) by arrrooohhh (Sydney Australia)   |   | |
Inside Electrolux 8kg version |
Post# 313995 , Reply# 5   11/9/2008 at 20:02 (5,643 days old) by arrrooohhh (Sydney Australia)   |   | |
Simpson 9 kg version. I like this one. |
Post# 314176 , Reply# 9   11/10/2008 at 16:33 (5,642 days old) by iheartmaytag (Wichita, Kansas)   |   | |
Here is what I understand with my limited knowledge on the subject. I know even on my Maytag TL manual it says linting can be caused from Overloading, or too little detergent. Detergent will hold the lint in suspension and prevent it from re-depositing. If you use too little, you end up with lint problems. If you use too much, you have a Brady Bunch episode. |
Post# 314506 , Reply# 12   11/12/2008 at 05:22 (5,641 days old) by twinniefan (Sydney Australia)   |   | |
Hi Shanon, What would be the main difference between your F.P. low profile agitator and the traditional type Asian pulsator,the reason I ask is we got the L.G. 8.5 kg Turbodrum about 5 months ago, and it seems to wash pretty well,we got it due to similar reason to yours i.e. large doona covers etc which were difficult to wash in the Haier T.T.,we learnt through experience and experimentation that tangling can be reduced and even avoided by washing a mixed load of clothes i.e. a few shirts,a few pants blouses etc, although I must add the 2 lint filters can be a bit of a bummer to clean out at times, so we do it after every wash when the lint has dried. I also learnt that sometimes when selecting the normal cycle, it does not seem to take in enough water so I just increase the water level manually by pushing the key,however if you select the fuzzy cycle,the "i sensor", does seem to get it right. You mention advertising, have you noticed that there does not really seem to be a lot of washer advertising on the television these days,unless I am watching the wrong channels. Cheers Shanon, Steve. |
Post# 316064 , Reply# 16   11/19/2008 at 18:50 (5,633 days old) by brisnat81 (Brisbane Australia)   |   | |
Depending on the capacity, around 70-90L per cycle. 7-10kg dry weight. They are an international electrolux design, so there is no reason they wont turn up in the US. |
Post# 316095 , Reply# 17   11/19/2008 at 23:30 (5,633 days old) by arrrooohhh (Sydney Australia)   |   | |
Surely it could easily wear a Frigidaire badge in the US. |
Post# 316124 , Reply# 18   11/20/2008 at 08:11 (5,633 days old) by bajaespuma (Connecticut)   |   | |
