Thread Number: 1958
Whirlpool LAX710 |
Post# 64867 , Reply# 1   4/30/2005 at 12:06 (6,932 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 64870 , Reply# 2   4/30/2005 at 12:59 (6,932 days old) by fixerman ()   |   | |
Doesn't seem to be a good model no. Can't find it on Sears site anyway. Please double check the model no. |
Post# 64871 , Reply# 3   4/30/2005 at 13:12 (6,932 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 65391 , Reply# 5   5/4/2005 at 02:34 (6,929 days old) by DADoES (TX, U.S. of A.)   |   | |
The model number doesn't make a match at RepairClinic.com, and I'm not sure if this is mid 1980s belt drive or a more recent direct drive machine. If it's direct-drive (there's no access panel on the back), there's not much to the drain process. The pump attaches directly to one end of the motor, driven directly by the motor shaft. The motor is reversible for agitate and spin/drain. When it runs in the agitate direction, the pump forces water back into the tub rather than draining it out. In the spin/drain direction, it drains. Or should. The pump apparently isn't frozen-up or the motor couldn't run at all. Perhaps the tub outlet is blocked by a stray sock or other small article that got out of the wash basket? If it's a belt-drive machine, then the pump could be frozen and the machine will still run, but under a load and not for long before the belt would/should start burning. Another possibility is that the flapper valve arm isn't properly engaged in the agitate shift bar, the flapper valve is broken and stuck in recirculate mode, or the impeller is loose from the pulley shaft. |
Post# 65454 , Reply# 7   5/4/2005 at 22:31 (6,928 days old) by mesabdb ()   |   | |
Sorry to send you on wild goose chases re: model number. I looked again. LA5710XPW3 or maybe LAS710XPW3 (not sure it's a number "5" or a letter "S") |
Post# 65455 , Reply# 8   5/4/2005 at 22:34 (6,928 days old) by mesabdb ()   |   | |
Thanks for patience, folks. I checked model # again. LA5710XPW3 or LAS710XPW3 (not sure if it's a letter "S" or a number "5") |
Post# 65461 , Reply# 9   5/4/2005 at 23:24 (6,928 days old) by DADoES (TX, U.S. of A.)   |   | |
For model LA5710XPW3, RepairClinic came up with two belt-drive pumps, a belt-drive Surgilator, a standard belt, and various other belt-drive components . . but there's also a direct-drive motor coupler in the listing! I'm thinking it's probably a belt-drive machine. Does it have a recirculating (removeable cartridge "bed-of-nails") lint filter? Does the filter work? Changing the pump is very simple, assuming that's the problem. Could be a hose is clogged, though. |
Post# 65464 , Reply# 11   5/5/2005 at 01:26 (6,928 days old) by fixerman ()   |   | |
It's a 1984 model |
