Thread Number: 1961
Frigidaire 1-18 Spin Seal Help |
Post# 64961 , Reply# 1   5/1/2005 at 06:58 (6,906 days old) by Goatfarmer (South Bend, home of Champions)   |   | |
If you're careful,a small screwdriver will remove a bellows clamp.However,I don't know how you would reinstall it without the tool.There is a large nut under the bellows assembly,that comes off to remove the tub support.I wouldn't be surprised if the tub support is "fused" to the shaft,and you might not be able to get it off without destroying it. Was there a problem with a leak,or something? When you mention spin seal,is this the small brass ring,with the rubber piece around it,that goes under the tub support? Or is it the piece that bolts to the outer tub,and holds the transmission up? They used to come as a set. kennyGF |
