Thread Number: 19685
Filter Flo Question For The Experts |
Post# 316198 , Reply# 1   11/20/2008 at 17:07 (5,632 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 316202 , Reply# 2   11/20/2008 at 17:24 (5,632 days old) by appnut (TX)   |   | |
It's "normal" what it is doing. Well, that "soak" designation was pure marketing crap. Essentially, one could fill the washer up at that point and have it agitate for a couple of minutes, then push the timer knob in and let it soak for however long ya wanted. Then pull out timer knob and let it complete the cycle and then start for the regular wash.
Post# 316207 , Reply# 3   11/20/2008 at 18:02 (5,632 days old) by jaytag (Atlanta)   |   | |
I agree. It will agitate at slow for 45 seconds then ramp up to fast for 15 seconds, then off to soak for 2 min then repeats then goes into drain spin. |
Post# 316215 , Reply# 4   11/20/2008 at 18:52 (5,632 days old) by volvoguy87 (Cincinnati, OH)   |   | |
I have had recent experience with GE 2 speed clutches. Yes, it is normal for it to start slow and then kick up to normal once the clutch parts get up to speed. Read the 1958 GE Filter Flo repair manual Robert scanned, it describes why and how this works. I can't quite grasp it, but it's pretty reliable. GE used the same 2-speed clutch for all the Filter Flos and even some before that. Also, your washer should not make any grinding noises. If it does, the bearing for the outer clutch drum (and the shaft extension) are likely worn. Changing the GE clutch isn't rocket science, but you may need help removing the pin (I sure did). Happy washing, Dave PS. The pump is located on top of the clutch and motor. If the pump leaks, it soaks the clutch and motor, leading to a likely bearing issue in the clutch. The motors are usually just fine. |
Post# 316219 , Reply# 5   11/20/2008 at 19:12 (5,632 days old) by tuthill ()   |   | |
I have a white filter-flo pan that may work for your machine! Email me if interested, and I will send you some pictures. |
Post# 316243 , Reply# 7   11/20/2008 at 20:31 (5,632 days old) by rickr (.)   |   | |
