Thread Number: 19759
Smart suds-saver that can work on any washer, great idea here..... |
Post# 317096 , Reply# 1   11/26/2008 at 22:26 (5,622 days old) by toggleswitch2 ()   |   | |
Using the rinse water presumes: 1- No chemicals used in the rinse. 2- No LCB left from washing whites. 3- Someone turns the valve to save the rinse water after the wash water has been dumped form the tank. |
Post# 317099 , Reply# 2   11/26/2008 at 23:18 (5,622 days old) by hometechdoc ()   |   | |
Is this guy wearing a Charles Manson shirt? Also, what type of dryer is that? |
Post# 317101 , Reply# 3   11/26/2008 at 23:40 (5,622 days old) by appnut (TX)   |   | |
Post# 317173 , Reply# 4   11/27/2008 at 15:28 (5,622 days old) by vivalalavatrice ()   |   | |
... and what about this!? sorry but only the italian version is now available |
Post# 317208 , Reply# 6   11/28/2008 at 04:44 (5,621 days old) by frigilux (The Minnesota Prairie)   |   | |
I wouldn't want that beast of a water tower sitting on my washer. Just bring back the standard suds-saver! Nearly every brand offered one in the 50's, 60's and early 70's. I realize not everyone has the space or plumbing for a storage tub/sink, but if companies offered a suds-saver on at least one or two models, I'll bet it would sell. I'd buy one. I grew up with a suds-saving 1960 Kenmore, and my mom saved many thousands of gallons of water over the life of that workhorse. But....I suppose it's just easier to buy an uber-efficient front-loader. The new LG's use less than 20 gallons of water to clean a huge load. Hard to beat that. |
Post# 317226 , Reply# 8   11/28/2008 at 08:35 (5,621 days old) by fnelson487 (Palm Springs, CA)   |   | |
Post# 317227 , Reply# 9   11/28/2008 at 08:36 (5,621 days old) by fnelson487 (Palm Springs, CA)   |   | |
Post# 317231 , Reply# 10   11/28/2008 at 09:20 (5,621 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
That's a 70's Speed Queen gas dryer - small, plug door on the front (probably a foot pedal opening) and the panel looks like a lighted top. That man in the video has plenty of room for another washer next to his Kenmore, no need for any tanks or valves. Move the drain hose from one into the second washer and then back to the drain. Save wash or rinse water, whatever you desire and use it as many times as you like. Laundry would be done faster than with one machine if you re-used the wash water as well. A simple submersible pump in a clean garbage can would suffice for this use, probably cheaper as well! |
Post# 317311 , Reply# 12   11/29/2008 at 06:11 (5,620 days old) by vulcanchef ()   |   | |
are washer pumps designed to lift water that high ? |
Post# 317312 , Reply# 13   11/29/2008 at 07:19 (5,620 days old) by logixx (Germany)   |   | |
Post# 317325 , Reply# 14   11/29/2008 at 11:00 (5,620 days old) by favorit ()   |   | |
cause their PCB have extra USB/other ports to manage chemicals pumps, printer and these watersaver (they DON'T save suds but interim rinse water) |
Post# 317327 , Reply# 15   11/29/2008 at 11:17 (5,620 days old) by favorit ()   |   | |
How does it work ? Can't help posting you this link ;-) Never seen before a TL Siwamat having the drum oriented as a FL CLICK HERE TO GO TO favorit's LINK on eBay |
Post# 317332 , Reply# 16   11/29/2008 at 13:40 (5,620 days old) by vivalalavatrice ()   |   | |
...so here you are a pic of the catalogue which circulated on these pages several months ago, I remember it was a Louis' picture. I'm strong convinced it has got the "sliding outer tub" either...:DD |
