Thread Number: 19868
Maytag A207 Brake squeak |
Post# 318421 , Reply# 1   12/6/2008 at 09:46 (5,613 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 318435 , Reply# 2   12/6/2008 at 11:38 (5,613 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Goatfarmer is correct. I have a little squirt bottle filled with Maytag tranny oil. You may have to remove the drive pulley on the transmission to get at it but you squirt a little oil into the brake package to lube it. Maytags use a wet brake system VS. Norge and/or others that use a dry brake like a car brake. Light oil does not seem to work as well so that's why you use a heavier oil like trans oil. I love those 'squeeks when it stops' calls because I'm in and out quick and on to the next... RCD |
Post# 318782 , Reply# 3   12/8/2008 at 10:38 (5,611 days old) by retodd1200 ()   |   | |
Thanks guys. I'll let you know how it goes. |
