Thread Number: 19876
Soap stuck in open compartment when finished-KUDS230B |
Post# 318559 , Reply# 1   12/7/2008 at 08:57 (5,589 days old) by cehalstead (Charleston, WV)   |   | |
the water flow to the soap dispenser was probably blocked by a tall piece in the machine. if this happens only once in a while, IMHO, the water flow is the problem, since the cover of the dispenser is opening. |
Post# 318563 , Reply# 2   12/7/2008 at 09:34 (5,589 days old) by kenmoreguy64 (Charlotte, NC)   |   | |
Check that the dispenser cover is not being blocked from opening all the way also. In my GE Tall tub The dispenser lid doesn't open all the way sometimes due to interference from the upper rack, especially if something heavy is in it. Opening the door will allow the cover to spring back the rest of the way and the detergent washes away almost immediately. Gordon |
Post# 319110 , Reply# 6   12/10/2008 at 07:19 (5,586 days old) by countryguy (Astorville, ON, Canada)   |   | |
Post# 319221 , Reply# 7   12/10/2008 at 22:09 (5,586 days old) by joe233 ()   |   | |
OK, but it doesn't happen all the time. It could be the way it was loaded. I'm going to try and keep the silverware basket less full in the middle near the soap doors. And a new box of Electrasol :-) |
Post# 319271 , Reply# 8   12/11/2008 at 08:33 (5,585 days old) by countryguy (Astorville, ON, Canada)   |   | |
Well by coincidence, I had the same thing happen to me last night - opened the dishwasher and the detergent tab is still in the dispenser. The only thing I did different was instead of putting the pizza pan (quite large) at the very left of the lower rack, I moved it over to the right by 1 row. What I think happened is that when the door is closed, the pizza pan butted right against the dispenser door stopping it from opening. Gary |
