Thread Number: 19923
Repair help for Amana Washer |
Post# 318988 , Reply# 1   12/9/2008 at 09:58 (5,615 days old) by coldspot66 (Plymouth, Mass)   |   | |
Needs a brake pad kit. Complete model & serial # will help. |
Post# 319152 , Reply# 2   12/10/2008 at 14:33 (5,614 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 319275 , Reply# 3   12/11/2008 at 09:17 (5,613 days old) by jaytag (Atlanta)   |   | |
Sorry about this. The tag is in a weird spot on the side of the unit. Model LW3503W Serial R9403066494 Thanks |
Post# 319280 , Reply# 4   12/11/2008 at 10:26 (5,613 days old) by coldspot66 (Plymouth, Mass)   |   | |
Part # is R9900543 retails for about $20-$25. |
Post# 319288 , Reply# 5   12/11/2008 at 11:42 (5,613 days old) by jaytag (Atlanta)   |   | |
I found a non working washer on CL. They want 25 for it, it leaks. Would a LW7503W be comperable to use the part out of? |
Post# 319312 , Reply# 6   12/11/2008 at 13:51 (5,613 days old) by coldspot66 (Plymouth, Mass)   |   | |
These machines wear down brake pads alot. The junk machine may have worn pads as well. Best just to order the part. |
Post# 319462 , Reply# 9   12/12/2008 at 13:08 (5,612 days old) by jaytag (Atlanta)   |   | |
The pump sits directly below the motor. I was planning to tackle it one pad at a time, undo the bolts pull out the pad and replace. The one in the back agreed, will be the hardest to do. |
Post# 319489 , Reply# 10   12/12/2008 at 15:44 (5,612 days old) by coldspot66 (Plymouth, Mass)   |   | |
Removing the motor/pump assy will make the job much easier. Just replacing the front 2 might cause them to wear faster, if the back one is not replaced as well. While you're at it, replace the belt...they chew through them too. |
Post# 319713 , Reply# 11   12/14/2008 at 14:22 (5,610 days old) by roto204 (Tucson, AZ)   |   | |
I lucked out on mine--it doesn't leak. From what I've heard by other members who have tackled these machines, if you do find one on Craigslist with the caveat "has small leak, should be easy to fix", run screaming in the opposite direction. The center seal assembly is neither easy nor fun to replace.
