Thread Number: 20412
Maytag WU600 moptor just died |
Post# 324892 , Reply# 1   1/17/2009 at 19:33 (5,576 days old) by qsd-dan (West)   |   | |
Post# 324896 , Reply# 2   1/17/2009 at 19:59 (5,576 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Make sure it's the motor. Use a test harness (which you can build easily...) and the diagram below. If the colors on the start switch are different, use the wiring diagram to match the right terminals. If I remember right, the schematic is behind the main panel glued to the inner door near the soap cup. You do not need to pull the motor out but you may find it easier to bench test it. If the motor runs ok, you may have something else going. If the motor's toast, you can try to find it. P/N 900201 For a donor, my cross ref shows compatibility with the WU200, WU400 & WC200 Good luck... RCD |
Post# 324916 , Reply# 4   1/17/2009 at 21:37 (5,576 days old) by qsd-dan (West)   |   | |
Post# 324919 , Reply# 5   1/17/2009 at 21:46 (5,576 days old) by maytagbear (N.E. Ohio)   |   | |
that's better than a new machine, plus, who knows how long a new one would run? Lawrence/Maytagbear |
