Thread Number: 20480
Removing agitator |
Post# 325739 , Reply# 2   1/21/2009 at 06:45 (5,544 days old) by kindalazy (toronto)   |   | |
I tried to remove the agitator from the bottom, but gave much resistance. Do the moving fins come off as well? |
Post# 325741 , Reply# 3   1/21/2009 at 07:00 (5,544 days old) by toggleswitch2 ()   |   | |
Pull from the top. |
Post# 325777 , Reply# 4   1/21/2009 at 10:13 (5,544 days old) by kenmoreguy64 (Charlotte, NC)   |   | |
If you want to take the whole agitator out, there is an agitator screw that secures the agitator to the agitator shaft which much be removed first. You will need a socket driver with an extension on most direct drive machines to do this. Be careful not to damage the seal on the screw, and be sure to re-install it properly as this seal is very important in keeping the centerpost dry on all DD machines. |
Post# 325903 , Reply# 5   1/21/2009 at 16:43 (5,544 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 325995 , Reply# 6   1/21/2009 at 22:42 (5,544 days old) by surgilator_68 (Maryland)   |   | |
It depends on how old the TT is. The original one is belt drive. You would know you have a belt drive because the lint filter is located at the 1 o'clock position on the tub cover. And the filter is usually missing or damaged. now..... there are two different DD TT. One is a Thin Twin, 24in wide, the SUPER Thin Twin is 27 inches wide. The Super TT has a dual action agitator. The 24in wide TT should (unless someone has changed it or screwed the top of the agitator to the bottom) have a 2 piece agitator with the filter in the bottom of the barrel. Simply put your hands around the barrel like you are going to choke your um, mother in law and pull up. Turn the barrel over and you'll see the lint clogged filter. Clean it and replace the barrel. Make sure you push the barrel firmly onto the bottom of the agitator or it will come off during spin. |
Post# 325996 , Reply# 7   1/21/2009 at 22:50 (5,544 days old) by johnb300m (Chicago)   |   | |
Post# 326009 , Reply# 8   1/22/2009 at 00:12 (5,544 days old) by dadoes (TX, U.S. of A.)   |   | |
Post# 326048 , Reply# 9   1/22/2009 at 07:28 (5,543 days old) by surgilator_68 (Maryland)   |   | |
It actually worked quite well. Better than what the ' new and improved' self cleaning filter is. Yes, it's in the owners manual to clean the filter. On a side note..... if any one of you get a chance to pull the agitator out on a direct drive made in the last 4 years notice the 4, then 2 round rubber and plastic plugs under the agitator with 3 fingers sticking out ( if they haven't fallen apart and been flushed down the drain).....that is the new lint filter. Yes, its a joke, but if you dry everything in the dryer and sort properly to begin with you don't need a lint filter in the washer anyway. |
