Thread Number: 20526
Maytag MAV8057 help |
Post# 326372 , Reply# 1   1/23/2009 at 20:01 (5,563 days old) by jaytag (Atlanta)   |   | |
Spot Stain etc button right of dial. |
Post# 326373 , Reply# 2   1/23/2009 at 20:02 (5,563 days old) by jaytag (Atlanta)   |   | |
lifetime tub |
Post# 326434 , Reply# 3   1/24/2009 at 08:07 (5,563 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 326447 , Reply# 4   1/24/2009 at 10:07 (5,562 days old) by revvinkevin (Tinseltown - Shakey Town - La-La Land)   |   | |
I have the MAV7600 and looks like it's a model or two below this one, but has a stainless steel wash basket. One the top... yes, you should be able to pull the top up from the front, just give it a good yank. The front panel has no screws, you have to pull the top up first, then you tilt the front panel out (away from the machine) and lift up. |
Post# 326456 , Reply# 5   1/24/2009 at 11:30 (5,562 days old) by redcarpetdrew (Fairfield, CA)   |   | |
To properly open her up, you need to take a putty knife and insert it inbetween the top and the front panel to gently push in two spring clips which will let you lift the top up like a hood. Then there are two 5/16" screws that attach the front panel to the cabinette. Remove them and the panel will tilt forward enough to lift it up off two hooks that hold the bottom of the panel on. Kevin, your machine may be missing the front panel screws... RCD |
Post# 326466 , Reply# 6   1/24/2009 at 12:12 (5,562 days old) by andrewinorlando ()   |   | |
So, how do these machines clean? Do you guys find that they're gentler on clothes than a Shredmore, but good cleaners? |
Post# 326482 , Reply# 7   1/24/2009 at 12:34 (5,562 days old) by stainfighter (Columbia, SC)   |   | |
Post# 326486 , Reply# 8   1/24/2009 at 13:05 (5,562 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 326522 , Reply# 9   1/24/2009 at 16:37 (5,562 days old) by askomiele (Belgium Ghent)   |   | |
That stainspot doesn't it just spays a small amount of water out of the inlet to wet the stains and rub some detergent in it? |
Post# 326534 , Reply# 10   1/24/2009 at 18:48 (5,562 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Robert, the soap dispenser was a reservoir that inserted into the lid. It had a tank that held liquid detergent, a button to dispense it and a slide control to control the amount that came out when you pushed the button. when you put the lid up, the spout was automatically postioned above the tub. They were removeable to clean which is why it's probably missing. Supposedly, the soap dispenser assy could be mounted in the lid of any MAV washer of that design. See the scan below. Goatfarmer (Kenny, right?), You are correct. This is the same thing as the Maycor made Norge/Magic Chef washer. It's the Herron drivetrain. The top is just sloped for looks... Askomiele, I believe that is a toggleswitch (no, not our toggles...) that activates the cold water valve with the lid up so you can spot treat a stain and you don't have a sink handy nearby. It was also called a 'fingertip faucet'. RCD |
Post# 326535 , Reply# 11   1/24/2009 at 18:50 (5,562 days old) by redcarpetdrew (Fairfield, CA)   |   | |
