Thread Number: 20567
my 1st wringer |
Post# 326700   1/25/2009 at 18:55 (5,568 days old) by dynaflow (rockingham nc)   |   | |
Post# 326702 , Reply# 1   1/25/2009 at 19:06 (5,568 days old) by qsd-dan (West)   |   | |
When I get a new (ok vintage) machine home, I usually use simple green to get the usual grit off. After a good scrubbing, I use cleaner wax to get the impurities out of the paint where the simple green couldn't. You'll be surprise what a good cleaner wax or mildly abrasive rubbing compound can clean/erase what would otherwise be thought of as permanent damage.
Post# 326747 , Reply# 2   1/26/2009 at 00:19 (5,568 days old) by laundromat (Hilo, Hawaii)   |   | |
Post# 326754 , Reply# 3   1/26/2009 at 00:46 (5,568 days old) by frontaloadotmy (the cool gay realm)   |   | |
Ron !! |
Post# 326787 , Reply# 4   1/26/2009 at 05:40 (5,568 days old) by gyrafoam (Wytheville, VA)   |   | |
I use Clorox "Clean-Up" to clean with. Then, Meguire's Cleaner Wax. Best combination I have ever found. |
Post# 326818 , Reply# 5   1/26/2009 at 08:50 (5,568 days old) by volvoguy87 (Cincinnati, OH)   |   | |
Sounds like you have plenty of cleaning advice, but how are the wheels? My friend Classiccaprice has a Maytag too but his wheels were shot. We found new ones at Ace, minus the breaks. No big deal on a level floor, but very interesting on one that isn't, talk about "mobile wash!" To remove the wheels, have someone tip the washer a little and put a block under one of the raised wheels and have them steady the washer. Take a hefty screwdriver and put the business end on top of the wheel to be removed (the wheel, not the metal housing). Take a rubber mallet and pound on the screw driver as close to the wheel as possible while you hold the handle steady. The wheel should just pop out after a few pounds. Take the new wheel, line it up, and use the rubber mallet to pound up on the bottom of the new wheel. You would be amazed at how much easier it will roll. Beware, however, that the wheel beneath the wringer is the hardest to replace because it bears the most weight and is the most difficult to remove due to having to lift/hold the weight. Don't lay the machine on its side because the transmission oil will leak out. Also, ALWAYS store it with the pressure on the wringer rollers released so you don't press flat spots into them. Congratulations and enjoy your new Maytag, Dave |
