Thread Number: 20809
Neptune MAH4000 Help |
Post# 330109 , Reply# 1   2/13/2009 at 11:04 (5,549 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Chances are your MAH4000 still has the orig. motor board and motor combo. You cannot get the old motor or motor board anymore as they have done a upgrade to the system that came with the LATER model MAH55/65/75's. Depending on your model/serial number combo, that noisy/bad motor may be covered under the ten year part warranty that motor came with. The motor and new control board come together in a kit P/N 12002039. This is a good thing to do. The new motor control comes with a line filter to protect it and the board really built better. I could cool my turbo diesel on with the heat sinks alone... The motor is also MUCH quieter. I upgraded my MAH4000AWW with the kit and haven't looked back. When you do the fix, make sure you replace the old Dayco belt with a new Hutchinson sourced belt. RCD |
Post# 330317 , Reply# 2   2/14/2009 at 14:54 (5,548 days old) by jaytag (Atlanta)   |   | |
Drew, thank you, I would love to get this going. Here are the numbers: Model MAH4000AWW Serial 40299932WF |
Post# 330335 , Reply# 3   2/14/2009 at 18:07 (5,548 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Mfg in March, 1999. Not currently showing registered. Do you have a sympathetic factory servicer over there? If so, they should be able to warranty the motor with the kit. But do so QUICKLY as you are right up against the 10 yr. part warranty by date of manufacture!!! Let me know if you hit any snags... RCD |
Post# 331264 , Reply# 5   2/19/2009 at 18:03 (5,543 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 331270 , Reply# 6   2/19/2009 at 18:32 (5,543 days old) by jaytag (Atlanta)   |   | |
I appreciate everything you do. Jay |
Post# 332334 , Reply# 7   2/25/2009 at 20:42 (5,537 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 332378 , Reply# 8   2/26/2009 at 07:51 (5,537 days old) by jaytag (Atlanta)   |   | |
Hi Drew, No I didnt get it. My email is Jablevson@aol.com. I will try sending you an email. Thanks |
Post# 332395 , Reply# 9   2/26/2009 at 10:57 (5,536 days old) by redcarpetdrew (Fairfield, CA)   |   | |
