Thread Number: 20914
Hotpoint dishwasher |
Post# 331422   2/20/2009 at 15:02 (5,542 days old) by countryford (Austin, MN)   |   | |
I've posted on here about my hotpoint dishwasher before. I'm again asking for any help regarding it. All it shows on the machine is a catalog # 10maj2 (I'm assuming catalog is the same as model?) My question about it is in regards to the motor and pump. Mine was originally a gravity drain, but I was told could have come with a pump. I want to install a pump for it, but I was told the motors were different weather it had the pump or not. I need to replace the motor, so thats not a big issue. I have the model # of the motor without the pump as well as the part number. but I need the model number for the motor with the pump. Also does anyone know where I could get the pump for it as well? will a newer style pump work? I appreciate any info. thanks.
Post# 331462 , Reply# 1   2/20/2009 at 20:11 (5,541 days old) by westyslantfront ()   |   | |
Hi Justin. Good luck with the machine. It is a beauty. Sure hope you can restore it. Ross |
Post# 331475 , Reply# 2   2/20/2009 at 23:19 (5,541 days old) by unimatic1140 (Minneapolis)   |   | |
If this machine is like the earlier Hotpoint models it used a separate electric pump. There might even be empty terminals on the timer for it, my gravity drain hotpoint has them. You can simply install a new GE plastic top-load washer pump in there as long as their is a way to electrically control the pump.
Post# 332090 , Reply# 4   2/24/2009 at 13:41 (5,538 days old) by countryford (Austin, MN)   |   | |
unimatic1140: I was under the impression that I could just hook up a newer style pump like you suggested. But when I was searching for a new motor. I was told that there were two different part numbers for the motor. Depending on weather or not it had the pump or gravity drain? So if I get the motor for the gravity drain machine, can I still install a drain pump on it? 1952crestwood: I appreciate your intrest in the machine, but even if I find I can't make it work, Steve and I will just keep it for decorations. We already have it in the spot in the kitchen till we can find the parts for it. This is what it looks like in the new kitchen |
Post# 332093 , Reply# 5   2/24/2009 at 14:20 (5,538 days old) by tlee618 ()   |   | |
Justin, it looks right at home there. Your kitchen is beautiful!! Great job on the countertops. |
Post# 332107 , Reply# 6   2/24/2009 at 16:09 (5,538 days old) by unimatic1140 (Minneapolis)   |   | |
unimatic1140: I was under the impression that I could just hook up a newer style pump like you suggested. But when I was searching for a new motor. I was told that there were two different part numbers for the motor. Depending on weather or not it had the pump or gravity drain? So if I get the motor for the gravity drain machine, can I still install a drain pump on it? Yes, just attach the pump on the outlet port to the gravity drain line. |
Post# 332125 , Reply# 7   2/24/2009 at 18:24 (5,538 days old) by mikepaquette ()   |   | |
Very nice VERY NICE dishwasher Mike |
Post# 332126 , Reply# 8   2/24/2009 at 18:26 (5,538 days old) by mikepaquette ()   |   | |
Would love to see a pic of the inside Mike |
Post# 332568 , Reply# 10   2/27/2009 at 09:02 (5,535 days old) by countryford (Austin, MN)   |   | |
