Thread Number: 21180
Maytag Dryer door change,Year? |
Post# 334550 , Reply# 1   3/9/2009 at 16:43 (5,498 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 334583 , Reply# 3   3/9/2009 at 20:17 (5,497 days old) by redcarpetdrew (Fairfield, CA)   |   | |
O.K., now I know what it is. Along the lines of a DE7600-DE9700 built around the early 90's. When you get right down to it, between the two you are looking at, they are the same dryers with the same drive system, capacity, suspension, electric components, etc. The newer one was Maytag trying to make a bigger opening door. Soon after that, they went to a design where it was reversible. That's the only difference: The size of the door opening. As I see it, your decision breaks down mostly to looks. Personally, I like the looks of the older dryer that would match the above pictured washer. Good luck! RCD |
