Thread Number: 21218
New Whirlpool Top Loading Washers |
Post# 334916   3/11/2009 at 14:43 (5,496 days old) by laundromat (Hilo, Hawaii)   |   | |
I am not as familiar with the new Whirlpool laundry line as I used to be.i went to Lowes and noticed that in their high end line of washers,the top frame that is above the actual tub, has 4 different openings that look similar to the Westinghouse made Frigidaires with their version of the Jet Circle Spray System.There are 4 different sections on the ring that are inverted and look like they could be spray valves that are incorporated on the ring.Enquiring minds need to know. |
Post# 335177 , Reply# 1   3/12/2009 at 18:52 (5,495 days old) by jaytag (Atlanta)   |   | |
I believe it is similar to the Kenmore Elite's Ultra Rinse, which was introduced about 3 years ago. It is said to better remove suds out of the clothes. |
Post# 335185 , Reply# 2   3/12/2009 at 19:26 (5,495 days old) by laundromat (Hilo, Hawaii)   |   | |
Post# 335194 , Reply# 3   3/12/2009 at 20:05 (5,495 days old) by dadoes (TX, U.S. of A.)   |   | |
This machine has been discussed in a previous thread. It has a new automatic water level sensing feature, no manual selection is provided. Triple spray fill flume integrated in the tub ring. Six wash temps (Tap Cold, Cold, Cool, Warm Colors, Warm Whites, Hot). Softener option switch which changes the rinse to a deep fill. Currently two Whirlpool models (58ESV and 57ESV), and the latest Kenmore 800.
Post# 335242 , Reply# 4   3/12/2009 at 23:48 (5,495 days old) by toggleswitch2 ()   |   | |
How does an automatic water-level sensing system work? |
Post# 335247 , Reply# 6   3/13/2009 at 00:22 (5,495 days old) by dadoes (TX, U.S. of A.)   |   | |
Agitate 10 minutes, I think, would be excessive. Whirlpool's tech advisory says it fills initially to a low level. Then agitate 10 seconds to insure the load is saturated. The electronic control takes a reading from the pressure switch along with data from the flow meter, calculates the required water level, with the remaining fill level done by volume per the flow meter. |
Post# 335251 , Reply# 7   3/13/2009 at 00:29 (5,495 days old) by vintagesearch ()   |   | |
ohh sorry :( SECONDS NOT MINUTES lol omg how i read wrong |
Post# 335262 , Reply# 8   3/13/2009 at 03:17 (5,495 days old) by logixx (Germany)   |   | |
