Thread Number: 21242
Newer Maytag on Craigslist |
Post# 335246   3/13/2009 at 00:13 (5,516 days old) by autowasherfreak ()   |   | |
How hard would this be to do? CLICK HERE TO GO TO autowasherfreak's LINK on Quadcities Craigslist |
Post# 335250 , Reply# 1   3/13/2009 at 00:28 (5,516 days old) by mayfan69 (Brisbane Queensland Australia)   |   | |
Post# 335254 , Reply# 2   3/13/2009 at 01:05 (5,516 days old) by arrrooohhh (Sydney Australia)   |   | |
What does the inside of an SAV look like? |
Post# 335255 , Reply# 3   3/13/2009 at 01:10 (5,516 days old) by pulsator (Saint Joseph, MI)   |   | |
Post# 335257 , Reply# 4   3/13/2009 at 01:56 (5,516 days old) by tuthill ()   |   | |
but I think it's fake.... |
Post# 335259 , Reply# 5   3/13/2009 at 02:22 (5,516 days old) by mayfan69 (Brisbane Queensland Australia)   |   | |
Here you go...more info from a previous thread about these machines..... Ash...they look pretty much the same as the Atlantis inside... CLICK HERE TO GO TO mayfan69's LINK |
Post# 335311 , Reply# 6   3/13/2009 at 11:49 (5,516 days old) by redcarpetdrew (Fairfield, CA)   |   | |
This is an Amana based machine after Maytag took over. Unless you have a fondness for burning your money and banging your head against a wall while watching it burn, I'd RUN, not walk, away. The basic issue is that the upper shaft of the transmission wasn't milled quite right so it turns in a kind of eliptical rotation. This knocks that crappy lip seal assy around which causes it to leak into the bearings. You will need to replace the transmission assy (which may or may NOT be under an extended part wtty), the tub seals, most likely the bearings. YUCK! "A handyman could possibly do it..." ROFLMAO!!! RCD |
Post# 335312 , Reply# 7   3/13/2009 at 12:15 (5,516 days old) by volvoguy87 (Cincinnati, OH)   |   | |
I had one too. Look at the link below. Bad bad bad bad machine! Dave CLICK HERE TO GO TO volvoguy87's LINK |
Post# 335316 , Reply# 8   3/13/2009 at 12:35 (5,516 days old) by autowasherfreak ()   |   | |
Okay, I think I will pass on it then. |
Post# 335327 , Reply# 9   3/13/2009 at 13:29 (5,516 days old) by goatfarmer (South Bend, home of Champions)   |   | |
