Thread Number: 21254
whirlpool dd no neutral drain! |
Post# 335359 , Reply# 1   3/13/2009 at 19:12 (5,520 days old) by dadoes (TX, U.S. of A.)   |   | |
The only relation the timer has to neutral drain is in providing the pause between agitate and drain so the tranny can mechanically shift, then again between drain and spin. If the timer is pausing consistently as it should, then the problem is in the tranny. There's a neutral drain repair kit available to replace the related parts.
