Thread Number: 21292
kd-12 timer motor surgery |
Post# 335731 , Reply# 1   3/15/2009 at 21:31 (5,513 days old) by soberleaf ()   |   | |
here are the two halves of the timer motor after i made the cuts with the dremel. the motor winding unit just popped right off. |
Post# 335732 , Reply# 2   3/15/2009 at 21:34 (5,513 days old) by soberleaf ()   |   | |
here are all the parts to the winding unit, the winding itself, they all came out easily with the help of an extremely small and sharp pointed screwdriver. |
Post# 335733 , Reply# 3   3/15/2009 at 21:36 (5,513 days old) by soberleaf ()   |   | |
picture please!!! where the hell is the pic??? oh here it is!! |
Post# 335736 , Reply# 4   3/15/2009 at 21:38 (5,513 days old) by soberleaf ()   |   | |
here is that little tiny coil, bet rewinding that would be fun! have no idea how to do it but if i could wire that small i think i would try anyway! |
Post# 335737 , Reply# 5   3/15/2009 at 21:41 (5,513 days old) by soberleaf ()   |   | |
coil fits in here. note lack of wire leads on above pic of coil itself, i broke them off long before that pic was taken. so much for trying to get that coil to work again! |
Post# 335738 , Reply# 6   3/15/2009 at 21:44 (5,513 days old) by soberleaf ()   |   | |
guess this is called the stator, correct me if i'm wrong here guys, it's not an armature, anyway it's a gear on a magnetic disk that gives the timer motor it's ability to turn anything! |
Post# 335740 , Reply# 7   3/15/2009 at 21:48 (5,513 days old) by soberleaf ()   |   | |
the above mentioned gear/magnetic disk whatever fits inside this part. |
Post# 335750 , Reply# 9   3/15/2009 at 22:46 (5,513 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 335791 , Reply# 10   3/16/2009 at 08:27 (5,513 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
A bobbin for sure. That spikey disc is the stator field coils, the field being induced into it by the coil below. That will cause a rotating field in the stator which will cause the rotor& gear to turn. No field no turn OR no lube no turn. Thanks for posting I have always wondered what was inside, I had looked at patents but they are way more detailled than this little motor. |
