Thread Number: 21311
1960 Maytag Highlander Restoration Progress (Pix) |
Post# 336042 , Reply# 1   3/17/2009 at 21:23 (5,517 days old) by ttuee2006 ()   |   | |
Now we have the underside of the tub ring |
Post# 336043 , Reply# 2   3/17/2009 at 21:24 (5,517 days old) by ttuee2006 ()   |   | |
Now for the tub itself... |
Post# 336044 , Reply# 3   3/17/2009 at 21:24 (5,517 days old) by ttuee2006 ()   |   | |
Inside of the Spin Basket... This part was a PAIN to de-lime |
Post# 336045 , Reply# 4   3/17/2009 at 21:25 (5,517 days old) by ttuee2006 ()   |   | |
Underneath the Spin Basket... |
Post# 336046 , Reply# 5   3/17/2009 at 21:26 (5,517 days old) by ttuee2006 ()   |   | |
Spin Basket post-cleanup... |
Post# 336047 , Reply# 6   3/17/2009 at 21:27 (5,517 days old) by ttuee2006 ()   |   | |
Under the spin basket after cleanup... |
Post# 336048 , Reply# 7   3/17/2009 at 21:28 (5,517 days old) by ttuee2006 ()   |   | |
Tub Ring post-cleanup... |
Post# 336049 , Reply# 8   3/17/2009 at 21:29 (5,517 days old) by ttuee2006 ()   |   | |
Clean tub ring, post-cleanup... |
Post# 336050 , Reply# 9   3/17/2009 at 21:29 (5,517 days old) by ttuee2006 ()   |   | |
Tub inside post-cleanup... |
Post# 336051 , Reply# 10   3/17/2009 at 21:30 (5,517 days old) by ttuee2006 ()   |   | |
Outside of the tub post-cleanup... |
Post# 336068 , Reply# 11   3/17/2009 at 23:15 (5,517 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 336090 , Reply# 12   3/18/2009 at 06:26 (5,517 days old) by christfr (st louis mo)   |   | |
Post# 336094 , Reply# 13   3/18/2009 at 07:45 (5,517 days old) by geoffdelp (SAUK RAPIDS)   |   | |
Looks great, Eric! It's a rewarding process, isn't it? Can't wait to see it when you get done. |
Post# 336180 , Reply# 15   3/18/2009 at 23:32 (5,516 days old) by whirlaway (Hampton Virginia)   |   | |
Just beautiful!!!!!!!!!!!!!!!!!!!!!!!!!! What did you get that scale off with? |
Post# 336200 , Reply# 17   3/19/2009 at 05:49 (5,516 days old) by kenmore81 ()   |   | |
Im hoping there will be a vid on you tube as well ;), Im subscribed. for how long I dont know lol. My you tube acct erases everthing for some reason |
Post# 336383 , Reply# 19   3/20/2009 at 03:13 (5,515 days old) by kenmore81 ()   |   | |
WOW.What a project, and a terrific job.Just The thought of painting the timer makes my hands shake lol, i cant do that unless its a stencil. |
Post# 336394 , Reply# 20   3/20/2009 at 04:21 (5,515 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Post# 336528 , Reply# 22   3/20/2009 at 22:09 (5,514 days old) by ttuee2006 ()   |   | |
The rusty agitator shaft and the top of the tranny... |
Post# 336529 , Reply# 23   3/20/2009 at 22:10 (5,514 days old) by ttuee2006 ()   |   | |
And of course the timer dial......which I'm currently working on |
Post# 336552 , Reply# 24   3/21/2009 at 00:06 (5,514 days old) by ttuee2006 ()   |   | |
Got the knob finished! And yes.....that IS the same knob! |
Post# 336553 , Reply# 25   3/21/2009 at 00:07 (5,514 days old) by ttuee2006 ()   |   | |
Let's try that again..... |
Post# 336568 , Reply# 26   3/21/2009 at 01:51 (5,514 days old) by qsd-dan (West)   |   | |
Post# 336856 , Reply# 28   3/22/2009 at 14:21 (5,512 days old) by ttuee2006 ()   |   | |
Here's how she turned out: |
Post# 336857 , Reply# 29   3/22/2009 at 14:22 (5,512 days old) by ttuee2006 ()   |   | |
The control panel didn't turn out as nice as I would have desired, but it's a FAR CRY from what it was! |
Post# 336860 , Reply# 30   3/22/2009 at 14:31 (5,512 days old) by ttuee2006 ()   |   | |
Of course for comparison, you've gotta understand what it looked like when it came home! The link below posts to the original thread in the archives section... CLICK HERE TO GO TO ttuee2006's LINK |
Post# 336878 , Reply# 31   3/22/2009 at 15:31 (5,512 days old) by qsd-dan (West)   |   | |
Well, the shaft and collar are still available but at the steep price of $91-110, depending where you purchase it :( CLICK HERE TO GO TO qsd-dan's LINK |
Post# 336932 , Reply# 33   3/22/2009 at 19:26 (5,512 days old) by qsd-dan (West)   |   | |
Post# 336934 , Reply# 34   3/22/2009 at 19:32 (5,512 days old) by autowasherfreak ()   |   | |
Wow, it looks great! What did you use to clean the dial with? |
Post# 336936 , Reply# 35   3/22/2009 at 19:42 (5,512 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 336939 , Reply# 37   3/22/2009 at 19:59 (5,512 days old) by ttuee2006 ()   |   | |
Here's some more pix from the restoration process... This one is of the right side before it was repainted.....what a wreck! |
Post# 336940 , Reply# 38   3/22/2009 at 20:00 (5,512 days old) by ttuee2006 ()   |   | |
The left side before being repainted... |
Post# 336941 , Reply# 39   3/22/2009 at 20:01 (5,512 days old) by ttuee2006 ()   |   | |
The Front before repainting... |
Post# 336942 , Reply# 40   3/22/2009 at 20:02 (5,512 days old) by ttuee2006 ()   |   | |
Shot of the front after it was painted... |
Post# 336944 , Reply# 41   3/22/2009 at 20:03 (5,512 days old) by ttuee2006 ()   |   | |
Stripped the base pan down to bare metal and repainted with 2 coats of "rusty metal" Rustoleum... |
Post# 336945 , Reply# 42   3/22/2009 at 20:04 (5,512 days old) by ttuee2006 ()   |   | |
Base Pan #2 |
Post# 336946 , Reply# 43   3/22/2009 at 20:05 (5,512 days old) by ttuee2006 ()   |   | |
Tub remounted on the base pan. New seals, spin bearing, and tub to pump hose. |
Post# 336947 , Reply# 44   3/22/2009 at 20:06 (5,512 days old) by ttuee2006 ()   |   | |
Cabinet remounted on base. New fill valve installed. |
Post# 336948 , Reply# 45   3/22/2009 at 20:07 (5,512 days old) by ttuee2006 ()   |   | |
Plumbing all cleaned up and remounted... |
Post# 336949 , Reply# 46   3/22/2009 at 20:08 (5,512 days old) by ttuee2006 ()   |   | |
Siphon break! |
Post# 336951 , Reply# 48   3/22/2009 at 20:18 (5,512 days old) by swestoyz (Cedar Falls, IA)   |   | |
If your attempts with epoxy fall short, you could always opt for a parts machine. More than likely you can find a 70's or 80's BOL 'Tag near by for cheep or nearly free. I can't say I've seen them by the thousands, but I haven't seen these get this bad on later machines (probably due to the non-splined Power Fins.) The machine came out stunning! Ben |
Post# 336953 , Reply# 49   3/22/2009 at 20:27 (5,512 days old) by qsd-dan (West)   |   | |
Post# 337005 , Reply# 50   3/23/2009 at 07:20 (5,512 days old) by countryguy (Astorville, ON, Canada)   |   | |
Wow, that is the same washer we had when I was growing up. I remember the day (around 1967 I think) we got it, actually it was in the evening and my mom, dad and I were down in the basement watching it work for the first time! Prior to that my mom had a wringer washer (don't know what brand it was). I do remember it had a black agitator and the lint catcher was chrome with the black cup on the top and the black rubber band on the bottom. My mom used that washer up until the day she died in 2001. I don't remember it ever needing a repair other than a new belt. Gary |
Post# 337971 , Reply# 51   3/26/2009 at 21:01 (5,508 days old) by ttuee2006 ()   |   | |
I FIXED THE SHAFT!!!!!! IT WORKS! IT WORKS!!!!! I'M STILL PINCHING MYSELF!!!!! Videos and an explanation to follow shortly! |
Post# 338022 , Reply# 52   3/26/2009 at 23:19 (5,508 days old) by ttuee2006 ()   |   | |
Very first video showing it running with NO LEAKS! CLICK HERE TO GO TO ttuee2006's LINK |
Post# 338025 , Reply# 55   3/26/2009 at 23:29 (5,508 days old) by ttuee2006 ()   |   | |
Taking it's place in the laundry room! (Temporarily of course...) |
Post# 338026 , Reply# 56   3/26/2009 at 23:31 (5,508 days old) by qsd-dan (West)   |   | |
Post# 338028 , Reply# 57   3/26/2009 at 23:36 (5,508 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 338034 , Reply# 58   3/26/2009 at 23:41 (5,508 days old) by autowasherfreak ()   |   | |
Wow, you did a great job on the old girl. She looks good, and sounds great! |
Post# 338041 , Reply# 60   3/26/2009 at 23:58 (5,508 days old) by ttuee2006 ()   |   | |
The Compulsory video! Wash.......WITH CLOTHES! CLICK HERE TO GO TO ttuee2006's LINK |
Post# 338045 , Reply# 61   3/27/2009 at 00:13 (5,508 days old) by qsd-dan (West)   |   | |
Post# 338277 , Reply# 63   3/28/2009 at 00:36 (5,507 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Can you post the model/serial? I didn't see it in the above posts. I just may have access to the orig service manual or at least I should be able to find some instructions on tear down and rebuilding of the trans and the brake package repair and adjustment. I can fax them to you or whatever... QSD can attest to the large amount of older books and manuals I have access to... The brake tool is still very much available and is a small price to pay for if you and your Maytags are to stay together for a while. That is if you don't already have it... RCD |
Post# 339153 , Reply# 65   3/31/2009 at 20:29 (5,503 days old) by redcarpetdrew (Fairfield, CA)   |   | |
