Thread Number: 21457
It's that time of year again - machines for parts or repair |
Post# 338147 , Reply# 1   3/27/2009 at 11:45 (5,480 days old) by supremewhirlpol ()   |   | |
The Kenmore 90 series( DD) |
Post# 338148 , Reply# 2   3/27/2009 at 11:46 (5,480 days old) by supremewhirlpol ()   |   | |
The Wascomat |
Post# 338150 , Reply# 3   3/27/2009 at 11:47 (5,480 days old) by supremewhirlpol ()   |   | |
The Lady Kenmore |
Post# 338151 , Reply# 4   3/27/2009 at 11:50 (5,480 days old) by supremewhirlpol ()   |   | |
The maytag |
Post# 338154 , Reply# 5   3/27/2009 at 12:13 (5,480 days old) by volvoguy87 (Cincinnati, OH)   |   | |
Do you know what's wrong with the belt drive Lady Kenmore electronic washer? Also, what transmission do you have in the Maytag, the old long stroke or the newer short stroke Orbital? I am moving to Cincinnati and if all goes to plan I will be arriving Monday evening. Perhaps we can help each other out a bit. Cheers, Dave |
Post# 338173 , Reply# 7   3/27/2009 at 14:23 (5,480 days old) by revvinkevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 338199 , Reply# 8   3/27/2009 at 16:29 (5,479 days old) by kenmoreguy64 (Charlotte, NC)   |   | |
"The Lady Kenmore has lots of issues. It basically needs to be all taken apart and painted. The outer drum needs to be serviced as well. The last time I used it, it leaked and was very noisy. I think this machine is kinda hard to find, but I'm sure it still has some good parts (electronic boards, etc)." My educated guess would be that if the machine is leaking badly externally, it is probably leaking internally through the centerpost as well. This eventually causes fouling of the gearcase oil, wear of the bearings and spin tube, and a loss of lubrication on the basket drive pulley. All those things in concert cause a machine to get noisy. There is very possibly oil spewed by the belt all through the lower cabinet. When this happens, all is not lost however if you're able to work on machines. I start by fully dismembering the machine, installing a new upper spin bearing (if not both) and new upper seal, and a new seal in the spin tube. If the gearcase is full of water or rusty oil, I replace that or thoroughly clean and re-oil the old one, and re-install. A new belt and pump are adviseable. Then of course fix the tub leak, and the machine should be good to go for almost another lifetime. This can all be done with about $50 in parts (if you use the old transmission) and about 8 - 10 hours of your time, assuming the machine comes apart without being stubborn. I have at least three electronic control panels if anyone needs parts from them. Gordon |
Post# 338208 , Reply# 10   3/27/2009 at 17:19 (5,479 days old) by volvoguy87 (Cincinnati, OH)   |   | |
I don't expect to get to Cincy until Monday evening at the earliest, assuming all goes well. Unfortunately, my housemate is not going to be off of work until Sunday. I'll need my housemate because he can help load and unload, and he is the one who owns a truck. I doubt I could fit a Lady Kenmore in my little Saab, even if it is a hatchback. Did I also see the Lady Kenmore's matching dryer as well? Is there anything wrong with the Maytag? A neighbor might be able to use it, otherwise if you are parting it out and there are parts nobody wants, I might be interested in a few for my housemate's A206. Thanks, Dave |
Post# 338221 , Reply# 12   3/27/2009 at 20:20 (5,479 days old) by queeny77 (BERWYN, ILLINOIS)   |   | |
Post# 338222 , Reply# 13   3/27/2009 at 20:22 (5,479 days old) by queeny77 (BERWYN, ILLINOIS)   |   | |
Post# 338231 , Reply# 14   3/27/2009 at 21:18 (5,479 days old) by supremewhirlpol ()   |   | |
no, the almond and white one is a Speed Queen. I think I'm keeping that one. Its the only one like it I've seen. |
Post# 338233 , Reply# 15   3/27/2009 at 21:21 (5,479 days old) by supremewhirlpol ()   |   | |
The Marathon: |
Post# 338234 , Reply# 16   3/27/2009 at 21:23 (5,479 days old) by supremewhirlpol ()   |   | |
closeup1 |
Post# 338235 , Reply# 17   3/27/2009 at 21:24 (5,479 days old) by supremewhirlpol ()   |   | |
closeup2 |
Post# 338236 , Reply# 18   3/27/2009 at 21:27 (5,479 days old) by supremewhirlpol ()   |   | |
That's not the original agitator though. I took the original out because it was smaller. I think I still have it though. I'll post pictures of it later. |
Post# 338238 , Reply# 19   3/27/2009 at 21:29 (5,479 days old) by supremewhirlpol ()   |   | |
closeup4 |
Post# 338307 , Reply# 20   3/28/2009 at 05:23 (5,479 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 339418 , Reply# 22   4/1/2009 at 18:49 (5,474 days old) by supremewhirlpol ()   |   | |
Does anyone want these machines or parts from them? |
Post# 339460 , Reply# 23   4/1/2009 at 22:01 (5,474 days old) by volvoguy87 (Cincinnati, OH)   |   | |
Post# 339481 , Reply# 24   4/1/2009 at 22:57 (5,474 days old) by supremewhirlpol ()   |   | |
Ok, so far Volvoguy87 has the Lady Kenmore, and Maytag. I have parted out the Wascomat (some parts are still available). The Electronic fabric care machine is still available. |
Post# 339532 , Reply# 25   4/2/2009 at 11:24 (5,474 days old) by xraytech (Rural southwest Pennsylvania )   |   | |
