Thread Number: 21466
Continental E Series |
Post# 338306 , Reply# 1   3/28/2009 at 05:17 (5,500 days old) by frigilux (The Minnesota Prairie)   |   | |
Post# 338323 , Reply# 2   3/28/2009 at 09:22 (5,499 days old) by mrb627 (Buford, GA)   |   | |
Post# 338328 , Reply# 3   3/28/2009 at 09:36 (5,499 days old) by pulsator (Saint Joseph, MI)   |   | |
The 20lb capacity model is available with either gravity drain or pumped drain plus it doesn't need to be bolted down! It appears that the model pictured above is actually the coin-operated version, the regular on -premise version has 8 cycles unless you get the more expensive controls then it has more. The machine is very programmable, you can even set the wash temp to the degree! Anywhere between 32F and 194F! However, the machine states that it cannot handle incoming water hotter than 175F.
CLICK HERE TO GO TO pulsator's LINK |
Post# 338335 , Reply# 4   3/28/2009 at 10:47 (5,499 days old) by mrb627 (Buford, GA)   |   | |
Thank You for the link. Unfortunately, I think these machines require a large space behind them for servicing, if my guess is correct. I seem to recall a phone conversation with a CG rep about 2 years ago. This rep wanted to present a business case for opening a laundramat in my area. He said they would put one of these machines in my home for 60 days to demo if I had the space for it. As I recall, space was too tight to allow this machine in my home. We would have to cut a hole in the wall to get it into the laundry area. MRB |
Post# 338366 , Reply# 6   3/28/2009 at 16:33 (5,499 days old) by launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Proves my point regarding what a "real" front load washing machine would cost, if it was built "like they used to be". One probably could shave off several hundred dollars by using timers and or cams, but still. Only other way to bring the cost down would be to sell a large enough volume of machines to recoup costs. L. |
Post# 338367 , Reply# 7   3/28/2009 at 16:35 (5,499 days old) by launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 338368 , Reply# 8   3/28/2009 at 16:39 (5,499 days old) by supremewhirlpol ()   |   | |
The hard-mount machines especially require space behind them for repairs such as motors, dump valves, etc. |
Post# 338372 , Reply# 9   3/28/2009 at 17:13 (5,499 days old) by launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 338426 , Reply# 10   3/28/2009 at 20:34 (5,499 days old) by ronhic (Canberra, Australia)   |   | |
Post# 338488 , Reply# 11   3/29/2009 at 00:13 (5,499 days old) by brettsomers ()   |   | |
lol |
Post# 338728 , Reply# 12   3/30/2009 at 06:27 (5,498 days old) by sudsman ()   |   | |
The same as with ANY machine overlaoding = dirty clothes |
