Thread Number: 21521
Leaking Filter Flo |
Post# 339088   3/31/2009 at 15:04 (5,498 days old) by moonvalleycacti ()   |   | |
Huh??? Does that sound easy to any one here or?? CLICK HERE TO GO TO moonvalleycacti's LINK on Phoenix Craigslist |
Post# 339117 , Reply# 1   3/31/2009 at 16:56 (5,498 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 339252 , Reply# 2   4/1/2009 at 08:56 (5,498 days old) by bobbyderegis (Boston)   |   | |
Could also be the top gasket! Bobby in Boston |
Post# 339355 , Reply# 3   4/1/2009 at 15:04 (5,497 days old) by peterh770 (Marietta, GA)   |   | |
The top of the machine is the top of the tub. There is a simple rubber gasket that goes around it, sealing the top and tub. Piece of cake, if that is what it is. If not, it could be the tub boot, another easy fix (if the bolts come out easy) If not, it could be the pump (I had a couple in the laundromat that only leaked when the motor reversed for drain/spin). Yet another easy fix. |
Post# 339359 , Reply# 4   4/1/2009 at 15:23 (5,497 days old) by moonvalleycacti ()   |   | |
Ok, email was sent.. We shall see |
Post# 339657 , Reply# 7   4/3/2009 at 09:12 (5,496 days old) by bajaespuma (Connecticut)   |   | |
Filter flo's have an overflow valve at the top of the outer tub that will siphon off the throw water if it's very vigorous or, even more likely, if there's a little something in the flush hole at the bottom partially clogging the drain. There are so many easy possibilities for this one we should probably contact the seller and be good samaritains.
Post# 339795 , Reply# 8   4/3/2009 at 23:52 (5,495 days old) by moonvalleycacti ()   |   | |
No answer back... Resent email but i think its sold |
