Thread Number: 21554
Maytag set, 12 y.o. kicked to the curb. |
Post# 339640 , Reply# 2   4/3/2009 at 06:27 (5,494 days old) by toggleswitch2 ()   |   | |
The relative had the Frigidaire F/L and Maytag T/L washers concurrently for over a year. |
Post# 339655 , Reply# 4   4/3/2009 at 09:06 (5,494 days old) by toggleswitch2 ()   |   | |
Thanks! Sounds like I could have eliminated the "Check switch" and had a running machine! Didn't think to "pry" earlier-- I never expected such a machine to get evicted. |
Post# 339658 , Reply# 5   4/3/2009 at 09:16 (5,494 days old) by bajaespuma (Connecticut)   |   | |
Post# 339662 , Reply# 6   4/3/2009 at 09:46 (5,494 days old) by lebron (Minnesota)   |   | |
Post# 339664 , Reply# 7   4/3/2009 at 10:10 (5,494 days old) by coldspot66 (Plymouth, Mass)   |   | |
Hi Steve, You can't eliminated the check switch...you'll cause a short if you do. BTW NLA on my end for the tub cover light lens. Sorry!! |
Post# 339745 , Reply# 9   4/3/2009 at 16:33 (5,493 days old) by xraytech (Rural southwest Pennsylvania )   |   | |
Post# 339773 , Reply# 12   4/3/2009 at 19:40 (5,493 days old) by laundromat (Hilo, Hawaii)   |   | |
Incorporated with the lid switch there IS a fuse.However,the part to replace it is another lid switch that,as I began to say ,is incorporated with the part.So,instead of just replacing the fuse alone,you need to replace that entire switch.When I worked at Direct Maytag in Altamonte Springs,Florida, I replaced a lot of them on machines customers were replacing with Neptunes.What a nightmare that became!!!
Post# 340086 , Reply# 14   4/5/2009 at 11:46 (5,492 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
