Thread Number: 21651
Maytag A606 out of balance |
Post# 340950 , Reply# 1   4/8/2009 at 14:29 (5,496 days old) by kenwashesmonday (Carlstadt, NJ)   |   | |
Is the tub close to centered when at rest? Do you have enough clothes in it? It will not spin right if it's under-loaded. Ken |
Post# 340952 , Reply# 2   4/8/2009 at 14:36 (5,496 days old) by volvoguy87 (Cincinnati, OH)   |   | |
Congratulations, you have one of the best washing machines produced. You should take care to be sure that it is properly adjusted, however, to ensure it serves you well for years to come. Make sure the washer is absolutely level. Don't just eyeball it, but check it with a real level (if you don't have one, you can get one from a hardware store). If it is not level, it will easily go off balance. The front legs have wrench flats so you can screw them into the frame or out of it as needed. There is also a nut on the legs which should be snugged against the underside of the frame to lock the legs in place. I have a similar Maytag and once I got it level, it became difficult to tell if it was agitating or spinning. It is possible to adjust the 3 springs, but it is very rare that that is necessary. Good luck, Dave |
Post# 340999 , Reply# 4   4/8/2009 at 17:00 (5,496 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 341047 , Reply# 5   4/8/2009 at 21:27 (5,495 days old) by redcarpetdrew (Fairfield, CA)   |   | |
