Thread Number: 2188
Beginning Restoration on Maytag 101P!! |
Post# 67800 , Reply# 2   5/23/2005 at 11:41 (6,905 days old) by CHRISTFR (st louis mo)   |   | |
i did the same machine 2 years ago and loved it. the machine is fun to work on and great then its done. you should start lookin for a water boot and replace that while you have it apart i learned the hard way on that one.. looks like all your wires are there and thats a good thing. the one i have had all the wires eaten away by mice. i wish you the all the best of luck with it and i know youll love it when its done. if you need any help let me know be glad to chris
Post# 67802 , Reply# 3   5/23/2005 at 11:56 (6,904 days old) by lesto (Atlanta)   |   | |
What is an agitamer? If you cut the agitator out will it be ruined or will you be able to reinstall it? I red bakelite is so rare I hope you don't have to replace it with a black one from some later AMP model. |
Post# 67825 , Reply# 12   5/23/2005 at 17:01 (6,904 days old) by geoffdelp (SAUK RAPIDS)   |   | |
Thanks for the info!! I'll stop at the auto parts store tomorrow on my lunch. I've never heard of PB Blaster before. You're right, if I can just get under it I KNOW I could really blast it out. |
Post# 67828 , Reply# 14   5/23/2005 at 17:25 (6,904 days old) by Goatfarmer (South Bend, home of Champions)   |   | |
Post# 67868 , Reply# 16   5/23/2005 at 22:35 (6,904 days old) by toggleswitch (New York City, NY)   |   | |
Degreaser? Try Lye in the form of spray oven cleaner. It is an awesome degreaser. ...I would test it on a sacrifcial piece of bakelite first, though Barring that: Ammonia...even weaker still..automatic dishwasher detergent. This stuff packs a lot of whallop as a degreaser as it very "basic" [oposite of acidic] GOOD LUCK! |
Post# 67933 , Reply# 19   5/24/2005 at 08:54 (6,904 days old) by Unimatic1140 (Minneapolis)   |   | |
Hi Geoff, its a good thing you couldn't get the Agitamer under that red bakelite agitator, it would have broken it into at least three pieces in no time flat. Filling the tub with very hot water might do the trick to loosen the agitator, but you will need long heat proof rubber gloves to try and pull it out. Hot water might not work either, I suspect the only way you are going to be able to get it out is to break it and replace the agitator. A later Maytag agitator will fit, but it wont have the float assembly :(. Is there a specific reason why you need to get the agitator off? Actually if you need to you can pull the tub and agitator out as a unit if you remove some parts from below the outer tub. |
Post# 67947 , Reply# 23   5/24/2005 at 10:39 (6,904 days old) by retromom ()   |   | |
Geoff: You really have your work cut out for you! I know you will really love that washer when you are done! What an awesome red agitator! This is going to be a fun one to watch! Venus |
Post# 67962 , Reply# 25   5/24/2005 at 13:01 (6,903 days old) by Unimatic1140 (Minneapolis)   |   | |
Post# 67963 , Reply# 26   5/24/2005 at 13:04 (6,903 days old) by geoffdelp (SAUK RAPIDS)   |   | |
Robert, if I jump the lid switch, will the unbalance switch still work? |
Post# 67967 , Reply# 27   5/24/2005 at 13:23 (6,903 days old) by lesto (Atlanta)   |   | |
I may be wrong but I don't think the AMPs have an unbalance switch. Anyway, I think Robert is right. Stop trying to remove the agitator or it will surely break and red bakelites are not easy to find. |
Post# 68042 , Reply# 28   5/24/2005 at 20:27 (6,903 days old) by Unimatic1140 (Minneapolis)   |   | |
Post# 68116 , Reply# 29   5/25/2005 at 08:28 (6,903 days old) by geoffdelp (SAUK RAPIDS)   |   | |
Thanks, Robert ... will it also bypass the water level, too? Will it always be set on "normal"? You're right ... I probably will never wash just one rug; I use the wringers for those!! :-) |
Post# 68154 , Reply# 30   5/25/2005 at 16:10 (6,902 days old) by Unimatic1140 (Minneapolis)   |   | |
Geoff there are two independent mercury switches in the lid. One senses when the lid is closed (you need to bypass this one) the other senses when the water level float in the agitator touches the black button underneath the lid. If you open the lid with the lid switch bypassed the mercury in the water level switch falls down to the bottom of the switch via gravity and the machine thinks the proper water level has been reached. You can set the water level to what ever you want and when agitation begins you can then open the lid. In summary, with the safety switched bypassed, if you open the lid when the machine is filling it will simply start to agitate. If you leave the lid closed during the fills the machine will start to agitate when the proper water level is reached. In my AMP I start the washer without any clothes in it with the lid closed and I let it fill for a minute. Then I open the lid and let agitation begin and add the detergent to mix in with the water with the agitator going. After 20 seconds or so I push the dial in and add the clothes and close the lid. I pull the dial back out and the machine fills to the proper level. When agitation begins again I can open the lid to watch the action. |
Post# 68222 , Reply# 33   5/26/2005 at 10:15 (6,902 days old) by Mayken4now (Panama City, Florida)   |   | |
Post# 68242 , Reply# 34   5/26/2005 at 13:39 (6,901 days old) by geoffdelp (SAUK RAPIDS)   |   | |
Steve ... thanks! I will give it a shot. |
Post# 68244 , Reply# 35   5/26/2005 at 13:49 (6,901 days old) by Gyrafoam (Wytheville, VA)   |   | |
Geoff, that is such good news as I know you did not want that agitator to break! I hope it will work for you now. |
Post# 68263 , Reply# 36   5/26/2005 at 16:05 (6,901 days old) by geoffdelp (SAUK RAPIDS)   |   | |
Thanks, Steve ... I'll let everyone know!! :-) |
